Fuching DJet issues *SOLVED*, Running out of things to try |
rjames |
Jun 12 2019, 12:19 AM
I'm made of metal Group: Members Posts: 3,913 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Last summer all of a sudden my car wouldn’t stay running. If I could get it started the idle would hunt and the car would die unless I kept on the gas. Lack of power at times. All somewhat erratic.
Found that the MPS wouldn’t hold vacuum. Replaced the bad mps with a known good one. Car idles high when cold (higher than I think it should ~1600 rpm) so AAR is good, then when it warms up idle hunts from ~900rpm to the point where it almost dies unless I open the throttle body bleed screw quite a bit and turn the ECU knob just a few clicks away from full clockwise. So I did the following hoping to fix the issue: Replaced all vac hoses including intake runner to plenum hoses. New intakecrunner gaskets Verified plenum isn’t leaking New throttle body gasket Installed NOS throttle body Rebuilt the distributor New condenser Rebuilt injectors and flow tested New fuel lines Fuel pump is less than 2 years old Set timing and dwell with advance disconnected New CHT (resistance reads 1.7 w/engine off @70 degrees in the garage) Calibrated the TPS, even unplugged it to take it out of the equation, didn’t change anything. ECU matches the MPS (both correct part #s for a ‘75 2.0) Tried a known good ECU from a ‘74, no change. Feels like the MPS needs to be calibrated...but then again, these are all the same symptoms I had with the old bad mps. Replacement mps is from a Jeff B and was tested, but I haven’t retested it to see if it’s holding vacuum. (Don’t have the necessary tool, but maybe that’s the next step) Help! What am I missing? |
914_teener |
Jun 12 2019, 06:12 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Post a pic of your engine compartment.
Are you running a decel valve? So your d jet setup is for a 74 2.0? |
rjames |
Jun 12 2019, 06:19 PM
I'm using the decal valve. 75 2.0 with smog removed. Using '75 ECU, MPS and appropriate CHT sensor. I just rebuilt the distributor and installed new trigger points- didn't change anything. Fuel pump is new, but that doesn't mean it's working correctly or the pressure is set correctly. That said, if it runs at ~1600 rpm when cold for a few minutes, it seems unlikely there's a fuel pump/pressure related issue. no? I'll try disconnecting the T1/ambient air sensor to see if that changes anything. Measuring fuel pressure is on the list too now. How do I tell if the distributer is working correctly? It still feels MPS related to me... |
Lo-Fi Version | Time is now: 24th April 2024 - 05:43 AM |
