Fuching DJet issues *SOLVED*, Running out of things to try |
rjames |
Jun 12 2019, 12:19 AM
I'm made of metal Group: Members Posts: 3,876 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Last summer all of a sudden my car wouldn’t stay running. If I could get it started the idle would hunt and the car would die unless I kept on the gas. Lack of power at times. All somewhat erratic.
Found that the MPS wouldn’t hold vacuum. Replaced the bad mps with a known good one. Car idles high when cold (higher than I think it should ~1600 rpm) so AAR is good, then when it warms up idle hunts from ~900rpm to the point where it almost dies unless I open the throttle body bleed screw quite a bit and turn the ECU knob just a few clicks away from full clockwise. So I did the following hoping to fix the issue: Replaced all vac hoses including intake runner to plenum hoses. New intakecrunner gaskets Verified plenum isn’t leaking New throttle body gasket Installed NOS throttle body Rebuilt the distributor New condenser Rebuilt injectors and flow tested New fuel lines Fuel pump is less than 2 years old Set timing and dwell with advance disconnected New CHT (resistance reads 1.7 w/engine off @70 degrees in the garage) Calibrated the TPS, even unplugged it to take it out of the equation, didn’t change anything. ECU matches the MPS (both correct part #s for a ‘75 2.0) Tried a known good ECU from a ‘74, no change. Feels like the MPS needs to be calibrated...but then again, these are all the same symptoms I had with the old bad mps. Replacement mps is from a Jeff B and was tested, but I haven’t retested it to see if it’s holding vacuum. (Don’t have the necessary tool, but maybe that’s the next step) Help! What am I missing? |
BeatNavy |
Jun 12 2019, 06:45 PM
Certified Professional Scapegoat Group: Members Posts: 2,922 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
If you disconnect the T1 sensor I just want to see if things get incrementally better. If so, that might suggest a lean condition (also possibly suggested by the hunting idle). From there you could look to the actual root cause. But without a wideband sensor or other info it's hard to tell what the actual situation is (too lean, too rich, neither), and so to some extent you're chasing your tail.
Normal MPS failure is toward a rich situation. Why do you think it's MPS related? MPS's are pretty easy to test. When you installed the new trigger points, did you calibrate them at all? |
rjames |
Jun 12 2019, 08:34 PM
If you disconnect the T1 sensor I just want to see if things get incrementally better. If so, that might suggest a lean condition (also possibly suggested by the hunting idle). From there you could look to the actual root cause. But without a wideband sensor or other info it's hard to tell what the actual situation is (too lean, too rich, neither), and so to some extent you're chasing your tail. Normal MPS failure is toward a rich situation. Why do you think it's MPS related? MPS's are pretty easy to test. When you installed the new trigger points, did you calibrate them at all? I have a wide band sensor. Will check readings tomorrow along with disconnecting the T1 sensor. I suspect the MPS because this all started happening when the original MPS went bad. Bought a replacement from Jeff Bowlsby that he tested and the same symptoms remained after install. Or maybe that’s a reason not to suspect the MPS. How do I rule out the distributor? |
Lo-Fi Version | Time is now: 29th March 2024 - 05:08 AM |
