Fuching DJet issues *SOLVED*, Running out of things to try |
rjames |
Jun 12 2019, 12:19 AM
I'm made of metal Group: Members Posts: 3,911 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Last summer all of a sudden my car wouldn’t stay running. If I could get it started the idle would hunt and the car would die unless I kept on the gas. Lack of power at times. All somewhat erratic.
Found that the MPS wouldn’t hold vacuum. Replaced the bad mps with a known good one. Car idles high when cold (higher than I think it should ~1600 rpm) so AAR is good, then when it warms up idle hunts from ~900rpm to the point where it almost dies unless I open the throttle body bleed screw quite a bit and turn the ECU knob just a few clicks away from full clockwise. So I did the following hoping to fix the issue: Replaced all vac hoses including intake runner to plenum hoses. New intakecrunner gaskets Verified plenum isn’t leaking New throttle body gasket Installed NOS throttle body Rebuilt the distributor New condenser Rebuilt injectors and flow tested New fuel lines Fuel pump is less than 2 years old Set timing and dwell with advance disconnected New CHT (resistance reads 1.7 w/engine off @70 degrees in the garage) Calibrated the TPS, even unplugged it to take it out of the equation, didn’t change anything. ECU matches the MPS (both correct part #s for a ‘75 2.0) Tried a known good ECU from a ‘74, no change. Feels like the MPS needs to be calibrated...but then again, these are all the same symptoms I had with the old bad mps. Replacement mps is from a Jeff B and was tested, but I haven’t retested it to see if it’s holding vacuum. (Don’t have the necessary tool, but maybe that’s the next step) Help! What am I missing? |
saigon71 |
Jun 16 2019, 06:12 AM
Senior Member Group: Members Posts: 1,995 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
You are running lean at idle. Try truning the ECU knob to the full clockwise position.
I don't know if it's the ethenol in the fuel or what, but my 914 idle hunts the least with mixture knob set to full right (clockwise). I don't think this will fix your problem, but may improve it. |
ChrisFoley |
Jun 16 2019, 07:28 AM
I am Tangerine Racing Group: Members Posts: 7,908 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
my 914 idle hunts the least with mixture knob set to full right (clockwise). This is a clear indication that the MPS is adjusted too lean. When the MPS is properly adjusted, the best idle can be found near the middle of idle mixture knob range. Of course I am assuming that no other FI problems are contributing to the lean running. |
Lo-Fi Version | Time is now: 20th April 2024 - 06:09 AM |
