Fuching DJet issues *SOLVED*, Running out of things to try |
rjames |
Jun 12 2019, 12:19 AM
I'm made of metal Group: Members Posts: 3,875 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Last summer all of a sudden my car wouldn’t stay running. If I could get it started the idle would hunt and the car would die unless I kept on the gas. Lack of power at times. All somewhat erratic.
Found that the MPS wouldn’t hold vacuum. Replaced the bad mps with a known good one. Car idles high when cold (higher than I think it should ~1600 rpm) so AAR is good, then when it warms up idle hunts from ~900rpm to the point where it almost dies unless I open the throttle body bleed screw quite a bit and turn the ECU knob just a few clicks away from full clockwise. So I did the following hoping to fix the issue: Replaced all vac hoses including intake runner to plenum hoses. New intakecrunner gaskets Verified plenum isn’t leaking New throttle body gasket Installed NOS throttle body Rebuilt the distributor New condenser Rebuilt injectors and flow tested New fuel lines Fuel pump is less than 2 years old Set timing and dwell with advance disconnected New CHT (resistance reads 1.7 w/engine off @70 degrees in the garage) Calibrated the TPS, even unplugged it to take it out of the equation, didn’t change anything. ECU matches the MPS (both correct part #s for a ‘75 2.0) Tried a known good ECU from a ‘74, no change. Feels like the MPS needs to be calibrated...but then again, these are all the same symptoms I had with the old bad mps. Replacement mps is from a Jeff B and was tested, but I haven’t retested it to see if it’s holding vacuum. (Don’t have the necessary tool, but maybe that’s the next step) Help! What am I missing? |
rjames |
Jun 21 2019, 09:34 PM
Playing with it again, now it only idles high when cold. After idling high (AAR is working), it warmed up, dropped idle to 1200 rpm and held there for a minute or so. Then it did it’s usual go from 1000 rpm then drop to almost 0 unless I opened the throttle body bleed screw quit a bit. This time it didn’t matter if the hose to the vacuum canister on the distributor was connected or not.
Now it runs for a few seconds with the idle fluctuation and dies after a few cyclyes. If there was a vacuum leak it would idle high, right? Could this all be sign of a bad distributor? (BTW, I verified the MPS holds vacuum). Ugh. |
914sgofast2 |
Jun 22 2019, 10:46 AM
Senior Member Group: Members Posts: 606 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
In my experience a vacuum leak causes the idle to hunt as the mps tries to adjust for it, resulting in your symptoms.
Lo-Fi Version | Time is now: 28th March 2024 - 04:27 PM |
