Fuching DJet issues *SOLVED*, Running out of things to try |
rjames |
Jun 12 2019, 12:19 AM
I'm made of metal Group: Members Posts: 3,914 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Last summer all of a sudden my car wouldn’t stay running. If I could get it started the idle would hunt and the car would die unless I kept on the gas. Lack of power at times. All somewhat erratic.
Found that the MPS wouldn’t hold vacuum. Replaced the bad mps with a known good one. Car idles high when cold (higher than I think it should ~1600 rpm) so AAR is good, then when it warms up idle hunts from ~900rpm to the point where it almost dies unless I open the throttle body bleed screw quite a bit and turn the ECU knob just a few clicks away from full clockwise. So I did the following hoping to fix the issue: Replaced all vac hoses including intake runner to plenum hoses. New intakecrunner gaskets Verified plenum isn’t leaking New throttle body gasket Installed NOS throttle body Rebuilt the distributor New condenser Rebuilt injectors and flow tested New fuel lines Fuel pump is less than 2 years old Set timing and dwell with advance disconnected New CHT (resistance reads 1.7 w/engine off @70 degrees in the garage) Calibrated the TPS, even unplugged it to take it out of the equation, didn’t change anything. ECU matches the MPS (both correct part #s for a ‘75 2.0) Tried a known good ECU from a ‘74, no change. Feels like the MPS needs to be calibrated...but then again, these are all the same symptoms I had with the old bad mps. Replacement mps is from a Jeff B and was tested, but I haven’t retested it to see if it’s holding vacuum. (Don’t have the necessary tool, but maybe that’s the next step) Help! What am I missing? |
Rand |
Jun 22 2019, 01:05 PM
I'd say not dizzy. The thing about the dizzy that affects idle timing is the vacuum ports / advance plates. You've been through that. Or have you? The gunk between the advance plates can cause intermittent sticking. Might need to take it all apart, clean, relube, and try try again. (I've been through that and can share pics and tips if you go there.)
Seriously at this point, just get a 123 dizzy. Even if it doesn't solve your problem, it's an upgrade you'll be happy with. You won't regret that expense even if it only rules out problems. |
rjames |
Jun 22 2019, 05:09 PM
I'd say not dizzy. The thing about the dizzy that affects idle timing is the vacuum ports / advance plates. You've been through that. Or have you? The gunk between the advance plates can cause intermittent sticking. Might need to take it all apart, clean, relube, and try try again. (I've been through that and can share pics and tips if you go there.) Seriously at this point, just get a 123 dizzy. Even if it doesn't solve your problem, it's an upgrade you'll be happy with. You won't regret that expense even if it only rules out problems. Rebuilt the distributor trying to fix this issue. A 123 dist is in my future but need to figure this out this first. Will try looking for vac leaks if I can keep it running long enough. Although I don’t see how it could be a vac leak if the rpms are low and it won’t stay running. Idle should be HIGH with a vac leak, no? |
Lo-Fi Version | Time is now: 25th April 2024 - 04:58 PM |
