Fuching DJet issues *SOLVED*, Running out of things to try |
rjames |
Jun 12 2019, 12:19 AM
I'm made of metal Group: Members Posts: 3,910 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Last summer all of a sudden my car wouldn’t stay running. If I could get it started the idle would hunt and the car would die unless I kept on the gas. Lack of power at times. All somewhat erratic.
Found that the MPS wouldn’t hold vacuum. Replaced the bad mps with a known good one. Car idles high when cold (higher than I think it should ~1600 rpm) so AAR is good, then when it warms up idle hunts from ~900rpm to the point where it almost dies unless I open the throttle body bleed screw quite a bit and turn the ECU knob just a few clicks away from full clockwise. So I did the following hoping to fix the issue: Replaced all vac hoses including intake runner to plenum hoses. New intakecrunner gaskets Verified plenum isn’t leaking New throttle body gasket Installed NOS throttle body Rebuilt the distributor New condenser Rebuilt injectors and flow tested New fuel lines Fuel pump is less than 2 years old Set timing and dwell with advance disconnected New CHT (resistance reads 1.7 w/engine off @70 degrees in the garage) Calibrated the TPS, even unplugged it to take it out of the equation, didn’t change anything. ECU matches the MPS (both correct part #s for a ‘75 2.0) Tried a known good ECU from a ‘74, no change. Feels like the MPS needs to be calibrated...but then again, these are all the same symptoms I had with the old bad mps. Replacement mps is from a Jeff B and was tested, but I haven’t retested it to see if it’s holding vacuum. (Don’t have the necessary tool, but maybe that’s the next step) Help! What am I missing? |
rjames |
Jul 6 2019, 08:59 AM
Stock 2.0 liter with correct/matching FI parts. MPS holds vacuum.
113 dizzy is set to ‘B’ to retard the timing at idle (like my stock setup). If vacuum leaks are gone, seems like that only leaves adjusting the MPS? Before my old MPS went bad, the car idled at 900 rpms. |
914_teener |
Jul 15 2019, 10:06 AM
914 Guru Group: Members Posts: 5,193 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Stock 2.0 liter with correct/matching FI parts. MPS holds vacuum. 113 dizzy is set to ‘B’ to retard the timing at idle (like my stock setup). If vacuum leaks are gone, seems like that only leaves adjusting the MPS? Before my old MPS went bad, the car idled at 900 rpms. Send us a picture how you have routed your vaccum lines to the 123. My quess is that you are using manifold vacumm instead of ported vacuum. Post a pic. |
rjames |
Jul 17 2019, 12:27 AM
Stock 2.0 liter with correct/matching FI parts. MPS holds vacuum. 113 dizzy is set to ‘B’ to retard the timing at idle (like my stock setup). If vacuum leaks are gone, seems like that only leaves adjusting the MPS? Before my old MPS went bad, the car idled at 900 rpms. Send us a picture how you have routed your vaccum lines to the 123. My quess is that you are using manifold vacumm instead of ported vacuum. Post a pic. 123 retard is connected to the retard port on the throttle body. There is no advance port on the throttle body on the later cars. That said, issue is the same even if the hose is disconnected from the distributor left unplugged. |
Lo-Fi Version | Time is now: 19th April 2024 - 05:03 AM |
