AFR reading lean, AFR table showing rich..., guessing an exhaust leak? Other options? |
VaccaRabite |
Jun 14 2019, 04:05 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
As I get closer to Dyno Day for my 914 (July 22), I have a theory about some of my drivability issues.
This car has modern EFI, not carbs or Djet/Ljet. It’s running MS2 through a Microsquirt controller. The car is clearly very rich. It bogs heavily coming off idle, to the point that it will sometime stall out if you don't dance the accelerator pedal just right at a stop sign or a traffic light. Last oil change I could also smell gas in the oil. And while Bob Hill ( @saigon71 )was driving my car the other night I occasionally saw puffs coming out of the muffler on overrun. Kinda cool, in a way, but not great.... lol. I hooked up my trusty ancient tuning laptop and opened up the AFR table while looking at the AFR meter. Where the table is showing ~13, the gauge was swinging ~15.5, especially just off idle, when the car got hot. So my theory is that the ECU is reacting to a false LEAN condition and dumping huge amount of gas into an already rich environment. So, my possibilities are:
@Eric_Shea @Mark_Henry @chrisfoley Thoughts? Zach |
VaccaRabite |
Jun 18 2019, 07:14 AM
Well, my theory was somewhat dashed yesterday afternoon, but also somewhat supported.
In the ECU, the AFR EGO was set to adjust fuel only under kPa 0 - it was turned off. I set it to activate under kPa 85 which means it will be active everywhere (after warmup) except WOT. However. Two missing bolts... One on each side. When the hell did this happen? (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1560863682.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1560863684.2.jpg) So, before I go to texas next week I need to replace and test to see if there is an improvement. Zach |
Lo-Fi Version | Time is now: 16th May 2024 - 09:37 PM |
