AFR reading lean, AFR table showing rich..., guessing an exhaust leak? Other options? |
VaccaRabite |
Jun 14 2019, 04:05 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
As I get closer to Dyno Day for my 914 (July 22), I have a theory about some of my drivability issues.
This car has modern EFI, not carbs or Djet/Ljet. It’s running MS2 through a Microsquirt controller. The car is clearly very rich. It bogs heavily coming off idle, to the point that it will sometime stall out if you don't dance the accelerator pedal just right at a stop sign or a traffic light. Last oil change I could also smell gas in the oil. And while Bob Hill ( @saigon71 )was driving my car the other night I occasionally saw puffs coming out of the muffler on overrun. Kinda cool, in a way, but not great.... lol. I hooked up my trusty ancient tuning laptop and opened up the AFR table while looking at the AFR meter. Where the table is showing ~13, the gauge was swinging ~15.5, especially just off idle, when the car got hot. So my theory is that the ECU is reacting to a false LEAN condition and dumping huge amount of gas into an already rich environment. So, my possibilities are:
@Eric_Shea @Mark_Henry @chrisfoley Thoughts? Zach |
Mark Henry |
Jun 18 2019, 08:38 AM
Where is the Lambda mounted?
I've measured a huge temp drop from one side of the flange (header/exchanger side) to the other side (muffler side), the lambda needs heat to give correct readings. So what I'm saying is the lambda has to be in the header/exchanger to give a correct readings. http://www.914world.com/bbs2/index.php?showtopic=338730 But this still doesn't explain to me why the ecu/meter have different readings. |
Lo-Fi Version | Time is now: 17th May 2024 - 12:06 AM |
