914-6 Fuel Line Size |
exsurfer |
Jun 15 2019, 08:10 AM
Newbie Group: Members Posts: 18 Joined: 2-June 19 From: La Canada Member No.: 23,187 Region Association: Southwest Region |
What are the factory fuel lines sizes on a 914-6, I can't find fuel section on PET 5
Had the orig. fuel pump serviced what to refresh the orig. lines. Thanks |
Mark Henry |
Jun 15 2019, 08:26 AM
The weber barbs are 8mm, 5/16" fuel hose works.
Not sure on the pump, I have a conversion. |
Mark Henry |
Jun 15 2019, 08:35 AM
Had the orig. fuel pump serviced what to refresh the orig. lines. I recommend against using the cloth braided hose, what's available is total (IMG:style_emoticons/default/stromberg.gif) I use FI hose rated SAE J30R9 or higher and FI clamps, better safe than sorry. |
gereed75 |
Jun 15 2019, 11:29 AM
Senior Member Group: Members Posts: 1,233 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
If you are talking tank to engine bay lines through tunnel, the SS lines provided by tangerine work fine, not sure of size. Not anything unusual.
Agree with Mark n hose type |
exsurfer |
Jun 15 2019, 11:43 AM
Thanks!
I'm looking for factory replacement as the car is bone stock w 80K miles. Been in my garage for over ten years. I want the original lines replaced. There is no need for high pressure F.I. lines. Using a stock pump that was recently service. It is my understanding the supply line from the tank is larger than the output line and the return line. I can't find 914-6 fuel diagrams anywere. This car is not on PET 5 that I can find. Thanks |
porschetub |
Jun 15 2019, 02:48 PM
Advanced Member Group: Members Posts: 4,695 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Thanks! I'm looking for factory replacement as the car is bone stock w 80K miles. Been in my garage for over ten years. I want the original lines replaced. There is no need for high pressure F.I. lines. Using a stock pump that was recently service. It is my understanding the supply line from the tank is larger than the output line and the return line. I can't find 914-6 fuel diagrams anywere. This car is not on PET 5 that I can find. Thanks F.I. hose is more durable and all I will use,basic hose seems to degrade faster with modern fuel from personal experience,the price difference means nothing from a safety point of view,you have a valuble car besides. I bought quality fabric covered hose but won't fit it after reading issues with it,do use the F.I.clamps as mentioned ,worries me to see many people don't (IMG:style_emoticons/default/sad.gif) . |
johnhora |
Jun 15 2019, 08:48 PM
Senior Member Group: Members Posts: 864 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
914-6 Fuel Pump
(S) Suction ....fuel tank to fuel pump OD 10mm (D) Discharge..fuel pump to carbs OD 8mm ® Return......fuel pump to fuel tank OD 8mm Original Plastic Lines... small line (return) 8mm....large line (suction) 10mm As mentioned the SS lines provided by tangerine are excellent. I used them to replace the aging plastic in my original 914-6...perfect fit. I purchased fuel hose here: https://www.belmetric.com/metric-hoses-c-14/ you can get OEM type fuel braided or smooth that are Multi-Fuel Hose-Ethanol Approved |
Lo-Fi Version | Time is now: 28th March 2024 - 11:14 AM |
