A/F bung, Can this be installed while in the car |
North Coast Jim |
Jun 15 2019, 11:21 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Looking to add an Air Fuel guage to help finalize my new carb install. Adding a bung for the O2 sensor it seems like I should remove the heat exchangers to help the fabricator add the bung. Is this needed or can it be done while in the car ?? Where to actually add the bung, any suggestions or pics.
Mark Henry |
Jun 15 2019, 02:29 PM
I've been doing some testing, but it was on a 914 2.0 DTM T4 into a bug conversion with a CSP 4/1 SS header into a SS corvette muffler, in/out same side.
A huge area of concern is on each side of the header and muffler flange, the muffler side I see a 150+F drop in temperature. Enough of temp drop that the sensor doesn't have enough heat to be optimal. I was very surprised to see how big of a temp drop it was each side of the exhaust flange. Temps were taken at the end of a 30 minute test run at 3000rpm with a laser gun. Wish I had a stock or SSI /4 to see what the temp in a stock muffler or triad is... For a six I'd put the bung on the header after the collector, but then this becomes a two meter system. |
SirAndy |
Jun 15 2019, 02:51 PM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
For a six I'd put the bung on the header after the collector, but then this becomes a two meter system. I only put one sensor in the header on the passenger side. Probably not ideal but it seems to be working just fine. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:54 PM |
