My FI Frustrations Continue, Still have engine cutting out |
dralf |
Jun 15 2019, 01:26 PM
Member Group: Members Posts: 230 Joined: 24-January 04 From: Dayton, Oh Member No.: 1,597 |
I keep purchasing components for my 1975 D Jet system but to no avail in solving the mystery of why it will sometimes cut out when the reves are about 2500 and the engine is under load. For those who have read my earlier posts, I now have new wiring harness, coil, points, condenser, cleaned the dizzy, new Auxiliary Air Valve, and cleaned all wire connections. Also replaced the fuel filter. My recent purchase was a new MPS for mine had a diaphragm leak. I drove around the block and was happy for the first lap since my adjusting the valves and timing seemed to improve acceleration. Unfortunately by my second lap the engine started to randomly cut out as it have before. My path forward is to replace the vacuum advance diaphragm on the dizzy which I found a leak. also to check the cylinder head temperature sensor, and the throttle position sensor. I there anything else I should be checking or replacing ? I am thinking about setting up my timing light inside the cabin so I can verify that during those times where the engine cuts out the spark plugs are still getting power. I hate to think my ECU is bad. Also where or who can check that out if it comes to that ?
dralf |
Jun 16 2019, 07:30 PM
Thank everyone for tips and things to look at so far ... yes I have cleaned connections and replaced the relays to insure they were 100% good.... will focus on the throttle position sensor and perhaps get a 123ignition distributor once I find who sells them.
ssuperflyoldguy |
Jun 17 2019, 01:25 AM
Member Group: Members Posts: 173 Joined: 15-November 15 From: NorCal - East Bay Baby! Member No.: 19,364 Region Association: None |
Thank everyone for tips and things to look at so far ... yes I have cleaned connections and replaced the relays to insure they were 100% good.... will focus on the throttle position sensor and perhaps get a 123ignition distributor once I find who sells them. Odd things to check - replace any wires in ignition system, have had a couple internally broken wires from the distributor to the coil. 3 x in 40 years. 2 of the breaks were where the internal wire went thru the body of distributor. it's the original wires that aren't usually replaced. Try a loaner distributor |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:30 AM |
