Pulling Stub axle, Into bearings |
shane |
Jun 15 2019, 07:01 PM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
Hi, I have my new rear bearings in and was going to pull my wheel hubs in by using my CV joint stub axles. My CV axles are hooked to the trans and I have the stub axle through the inside of the bearing. I previously watched this video https://youtu.be/lnXdjTate5o and in it the guy uses his castle nut to put the stub axle through the inside of the bearing. Problem is my stub axle doesn’t come out through the inside of the bearing far enough to put the cast but on let alone the washer and the cast nut. Am I missing something?
Jun 15 2019, 07:07 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
There are better ways to install the bearings documented on this site and pelican.
shane |
Jun 15 2019, 07:16 PM
bbrock |
Jun 15 2019, 08:05 PM
Are the splines on your stubs and inside hub clean and free of rust and debris? I can easily slide mine in far enough by hand to grab at least 203 threads with the castle nut without the washer on. The turn the nut by hand to pull it far enough to add the washer. I haven't pulled them any farther because I'm waiting on new cv bolts to attach the axle first.
shane |
Jun 15 2019, 08:17 PM
Are the splines on your stubs and inside hub clean and free of rust and debris? I can easily slide mine in far enough by hand to grab at least 203 threads with the castle nut without the washer on. The turn the nut by hand to pull it far enough to add the washer. I haven't pulled them any farther because I'm waiting on new cv bolts to attach the axle first. I have the car on blocks, maybe I should jack up the swing arm a little to make sure the stub axle is reaching out far enough? |
Chi-town |
Jun 15 2019, 09:56 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Take a good stiff wire brush and scrub the inner splines of the hub until the shine (IMG:style_emoticons/default/laugh.gif) then grease them
Do the same with the stubs Leave the inner CV unbolted until you have the outer splines all the way in. |
shane |
Jun 15 2019, 10:32 PM
Take a good stiff wire brush and scrub the inner splines of the hub until the shine (IMG:style_emoticons/default/laugh.gif) then grease them Do the same with the stubs Leave the inner CV unbolted until you have the outer splines all the way in. It’s odd I jacked up my swing arm a bit just to make sure the stub axle face will sit flush with the inner bearing race and it does. But when I slide the wheel hub flush with the outer bearing race and push the two races together and against the face of the stub axle the splines aren’t even really close enough to come together yet and the thread on the stub axle is just flush with the wheel hub so I can start a castle nut to tighten it. I’m just going to chalk it up to one of those my car only things and use allthread a nut and some washers to pull the hub into the bearings and then hopefully I can still get my axles in without having to take the stub axle off my cv and mess up my paper gaskets. Thanks as usual for all the great help I’ll sure be glad when this (IMG:style_emoticons/default/ar15.gif) little bundle of joy is finally finished. Happy teening all (IMG:style_emoticons/default/aktion035.gif) |
rick 918-S |
Jun 16 2019, 04:42 AM
Hey nice rack! -Celette Group: Members Posts: 20,354 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
rgalla9146 |
Jun 16 2019, 05:36 AM
Advanced Member Group: Members Posts: 4,538 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
He's trying to pull the wheel hub into the installed bearing.
it's a press fit It can be done with threaded rod and a couple big ass washers. the stub axle and hub will never come close to reaching each other. after the hub is drawn in the stub axle will slide right in. |
bbrock |
Jun 16 2019, 07:46 AM
He's trying to pull the wheel hub into the installed bearing. it's a press fit It can be done with threaded rod and a couple big ass washers. the stub axle and hub will never come close to reaching each other. after the hub is drawn in the stub axle will slide right in. Ah! Yes, I missed that. I got in my head that the hub was already in and he was just trying to bet the stub axle in. I used the HF front wheel bearing kit for that. Slight fancier version of threaded rod and washers. Carry on (IMG:style_emoticons/default/beerchug.gif) |
shane |
Jun 16 2019, 07:55 AM
He's trying to pull the wheel hub into the installed bearing. it's a press fit It can be done with threaded rod and a couple big ass washers. the stub axle and hub will never come close to reaching each other. after the hub is drawn in the stub axle will slide right in. Ah! Yes, I missed that. I got in my head that the hub was already in and he was just trying to bet the stub axle in. I used the HF front wheel bearing kit for that. Slight fancier version of threaded rod and washers. Carry on (IMG:style_emoticons/default/beerchug.gif) My fault, the title of my thread was wrong. |
shane |
Jun 16 2019, 11:04 AM
Now that I have my drive axles inner CV joint bolted to the trans and can’t use the stub axle side to pull my wheel hub in, I’m going to have to pull the drive axle back out. I don’t suppose there is any way to separate the CV joint from the trans without destroying the paper gasket? Sometimes watching other people’s videos and there techniques that mysteriously work for them lead you down a bad road. Should have first made sure it was possible before I started to copy the video (IMG:style_emoticons/default/WTF.gif) can order more gaskets Just was hoping to finish that task today.
rgalla9146 |
Jun 16 2019, 01:01 PM
Now that I have my drive axles inner CV joint bolted to the trans and can’t use the stub axle side to pull my wheel hub in, I’m going to have to pull the drive axle back out. I don’t suppose there is any way to separate the CV joint from the trans without destroying the paper gasket? Sometimes watching other people’s videos and there techniques that mysteriously work for them lead you down a bad road. Should have first made sure it was possible before I started to copy the video (IMG:style_emoticons/default/WTF.gif) can order more gaskets Just was hoping to finish that task today. The gaskets are not likely to survive. They can survive if you don't mind leaving chisel marks on your inside CVs Aim the chisel away from the flange into the outside surface of the CV... NOT into the gasket groove. Alternate between sides at the roll pin area Are your heat exchangers on ? |
shane |
Jun 16 2019, 01:36 PM
Now that I have my drive axles inner CV joint bolted to the trans and can’t use the stub axle side to pull my wheel hub in, I’m going to have to pull the drive axle back out. I don’t suppose there is any way to separate the CV joint from the trans without destroying the paper gasket? Sometimes watching other people’s videos and there techniques that mysteriously work for them lead you down a bad road. Should have first made sure it was possible before I started to copy the video (IMG:style_emoticons/default/WTF.gif) can order more gaskets Just was hoping to finish that task today. The gaskets are not likely to survive. They can survive if you don't mind leaving chisel marks on your inside CVs Aim the chisel away from the flange into the outside surface of the CV... NOT into the gasket groove. Alternate between sides at the roll pin area Are your heat exchangers on ? Nope, that was going to be my next project installing my heat exchangers and new muffler. |
Jun 16 2019, 01:57 PM
Now that I have my drive axles inner CV joint bolted to the trans and can’t use the stub axle side to pull my wheel hub in, I’m going to have to pull the drive axle back out. I don’t suppose there is any way to separate the CV joint from the trans without destroying the paper gasket? Sometimes watching other people’s videos and there techniques that mysteriously work for them lead you down a bad road. Should have first made sure it was possible before I started to copy the video (IMG:style_emoticons/default/WTF.gif) can order more gaskets Just was hoping to finish that task today. The gaskets are not likely to survive. They can survive if you don't mind leaving chisel marks on your inside CVs Aim the chisel away from the flange into the outside surface of the CV... NOT into the gasket groove. Alternate between sides at the roll pin area Are your heat exchangers on ? Nope, that was going to be my next project installing my heat exchangers and new muffler. I've had luck separating the CV's by tapping around them with a hammer until they seperate. At least the ones that have been apart in the last couple years. But I always have extra cv gaskets since they do rip easily. |
shane |
Jun 16 2019, 02:13 PM
Now that I have my drive axles inner CV joint bolted to the trans and can’t use the stub axle side to pull my wheel hub in, I’m going to have to pull the drive axle back out. I don’t suppose there is any way to separate the CV joint from the trans without destroying the paper gasket? Sometimes watching other people’s videos and there techniques that mysteriously work for them lead you down a bad road. Should have first made sure it was possible before I started to copy the video (IMG:style_emoticons/default/WTF.gif) can order more gaskets Just was hoping to finish that task today. The gaskets are not likely to survive. They can survive if you don't mind leaving chisel marks on your inside CVs Aim the chisel away from the flange into the outside surface of the CV... NOT into the gasket groove. Alternate between sides at the roll pin area Are your heat exchangers on ? Nope, that was going to be my next project installing my heat exchangers and new muffler. I've had luck separating the CV's by tapping around them with a hammer until they seperate. At least the ones that have been apart in the last couple years. But I always have extra cv gaskets since they do rip easily. Great thanks, I’ll try your advice maybe it’ll work since I’ve only had them together for about 24 hours. If not it definitely won’t be the first time I’ve ran into a set back on that car. I still have the killmat, carpet and interior to install if I have to wait for paper gaskets, And I’ll definitely order extra. |
Lo-Fi Version | Time is now: 29th March 2024 - 01:27 AM |
