Rear trunk hinge |
Rear trunk hinge |
mangrum |
Jun 16 2019, 02:05 PM
Member Group: Members Posts: 180 Joined: 10-September 03 From: Ann Arbor, MI Member No.: 1,134 |
The plastic roller for the spring rod of the rear trunk lid hinge looks like it’s about to come off of the shaft. What techniques do folks use for releasing the tension of the spring? Is it then just a matter of pushing the roller further onto the shaft and putting the spring back in place?
Thanks, Mike |
RenoRoger |
Jun 16 2019, 03:04 PM
Member Group: Members Posts: 95 Joined: 11-November 10 From: Reno, NV Member No.: 12,370 Region Association: Northern California |
The plastic roller for the spring rod of the rear trunk lid hinge looks like it’s about to come off of the shaft. What techniques do folks use for releasing the tension of the spring? Is it then just a matter of pushing the roller further onto the shaft and putting the spring back in place? Thanks, Mike I recently replaced my rollers with new ones. Someone suggested to use water pump pliers to push down the torsion bar (spring). that didn't work for me. I took a 30" long iron pipe with 1" OD and 3/4" ID and cut a slot into it about 1/2" from one end just wide enough to fit around the spring. I was able to push down on the spring, slide off the old and put on the new. Still a very dangerous undertaking. Be careful... |
Lo-Fi Version | Time is now: 9th May 2024 - 03:23 AM |
