Bosch vaccum cannister interchangeability, can you swap between dizzies? |
bbrock |
Jun 24 2019, 10:43 PM
I rebuilt my Bosch 2.0L dizzy (p/n 039 905 205) but the vacuum canister is bad so I used a good one from a 1.7L dizzy I have on hand. The PET lists these as different part numbers and now I'm wondering if I need to track down the correct canister for this dizzy. Anyone know how much difference in advance between canisters and if it will make a difference? I'm going to be running Webers for now but may eventually restore the D-Jet and install.
IronHillRestorations |
Jun 25 2019, 06:03 AM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You'd be better off using a 1.8 distributor
bbrock |
Jun 25 2019, 07:30 AM
You'd be better off using a 1.8 distributor I've read that the 1.8 is the preferred "stock" dizzy for carbs but my thought is to try one I already have first and if I have to buy a different dizzy, I will probably buy an SVDA for carbs. I've been curious why the 1.8 is better though. Does it have a better advance curve, or is it just because of the lack of injector triggers? I pulled my triggers and made a blanking plate for the hole. (IMG:http://www.914world.com/bbs2/uploads/post-20845-1558413627.jpg) |
Lo-Fi Version | Time is now: 19th May 2024 - 06:13 PM |
