Bosch vaccum cannister interchangeability, can you swap between dizzies? |
bbrock |
Jun 24 2019, 10:43 PM
I rebuilt my Bosch 2.0L dizzy (p/n 039 905 205) but the vacuum canister is bad so I used a good one from a 1.7L dizzy I have on hand. The PET lists these as different part numbers and now I'm wondering if I need to track down the correct canister for this dizzy. Anyone know how much difference in advance between canisters and if it will make a difference? I'm going to be running Webers for now but may eventually restore the D-Jet and install.
IronHillRestorations |
Jun 25 2019, 06:03 AM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You'd be better off using a 1.8 distributor
bbrock |
Jun 25 2019, 07:30 AM
You'd be better off using a 1.8 distributor I've read that the 1.8 is the preferred "stock" dizzy for carbs but my thought is to try one I already have first and if I have to buy a different dizzy, I will probably buy an SVDA for carbs. I've been curious why the 1.8 is better though. Does it have a better advance curve, or is it just because of the lack of injector triggers? I pulled my triggers and made a blanking plate for the hole. (IMG:http://www.914world.com/bbs2/uploads/post-20845-1558413627.jpg) |
914_teener |
Jun 25 2019, 10:28 AM
914 Guru Group: Members Posts: 5,201 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
You'd be better off using a 1.8 distributor I've read that the 1.8 is the preferred "stock" dizzy for carbs but my thought is to try one I already have first and if I have to buy a different dizzy, I will probably buy an SVDA for carbs. I've been curious why the 1.8 is better though. Does it have a better advance curve, or is it just because of the lack of injector triggers? I pulled my triggers and made a blanking plate for the hole. (IMG:http://www.914world.com/bbs2/uploads/post-20845-1558413627.jpg) Get the 123 with bluetooth. Good luck. |
bbrock |
Jun 25 2019, 01:29 PM
Get the 123 with bluetooth. Good luck. That would be cool but a couple problems with that. First is $$$. It's not in the budget. Second is the good chance I'll be restoring the original D-Jet and putting it back on after a few years depending on my experience with the carbs. From what I can tell, that would require a different model of 123 dizzy than for carbs. I definately don't have the budget to buy two of them. They look cool though. (IMG:style_emoticons/default/smile.gif) I did put a Pertronix in mine though so at least I'll be points free. I think this stock dizzy will at least be a step up from the 050 I bought back in the 80s for this project but never used. (IMG:style_emoticons/default/beerchug.gif) |
porschetub |
Jun 25 2019, 02:31 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Get the 123 with bluetooth. Good luck. I did put a Pertronix in mine though so at least I'll be points free. I think this stock dizzy will at least be a step up from the 050 I bought back in the 80s for this project but never used. (IMG:style_emoticons/default/beerchug.gif) You will like the Pertronix especially for starting ,also IMO the initial warm-up is better with carbs that have no chokes,they just seem to run better and less "cold blooded'' till up to temp. The above was the first thing I noticed when I fitted Ignitor I to my VW T2 camper years ago,been real happy with these units ever since. |
Lo-Fi Version | Time is now: 30th May 2024 - 11:20 AM |
