vin question, two number plates missing |
drifter914 |
Jun 29 2019, 05:27 PM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
Hi Guys... I bought a '74 914 with Indiana title showing the same vin as on the windshield frame tag & the tag riveted to passenger side front wheelwell. Both of these tags are easily replaceable.
The vin sticker inside driver door jamb is missing & the number stamped on top of pass. wheelwell has been ground off ... gone ! The number stamped inside rear trunk floor on pass. side is a different number & is only 7 digits. Should this number be the same as vin ? So... so do I have a vin swap situation here... ? I can understand maybe removing the sticker inside the driver door jamb for a repaint, but to grind off the number stamped into the metal on top of front pass. wheelwell seems very intentional & for what purpose ? Is the number stamped inside rear trunk floor supposed to match vin on title ? Not completely sure what I have here... possible vin swap ? I feel the number in rear trunk floor may be key to solution. (IMG:style_emoticons/default/confused24.gif) What say you ... Thanks... Terry in Az |
porschetub |
Jun 30 2019, 03:20 AM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Front clip done maybe,if you have title you should be ok ? different rules in my country ALL numbers must be there.
You say the inner fender numbers are ground off ? can't be done as they are depressed number indentations...maybe they have been filled over my guess anyway. |
Lo-Fi Version | Time is now: 17th May 2024 - 12:03 AM |
