vin question, two number plates missing |
drifter914 |
Jun 29 2019, 05:27 PM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
Hi Guys... I bought a '74 914 with Indiana title showing the same vin as on the windshield frame tag & the tag riveted to passenger side front wheelwell. Both of these tags are easily replaceable.
The vin sticker inside driver door jamb is missing & the number stamped on top of pass. wheelwell has been ground off ... gone ! The number stamped inside rear trunk floor on pass. side is a different number & is only 7 digits. Should this number be the same as vin ? So... so do I have a vin swap situation here... ? I can understand maybe removing the sticker inside the driver door jamb for a repaint, but to grind off the number stamped into the metal on top of front pass. wheelwell seems very intentional & for what purpose ? Is the number stamped inside rear trunk floor supposed to match vin on title ? Not completely sure what I have here... possible vin swap ? I feel the number in rear trunk floor may be key to solution. (IMG:style_emoticons/default/confused24.gif) What say you ... Thanks... Terry in Az |
914werke |
Jul 1 2019, 10:37 AM
"I got blisters on me fingers" Group: Members Posts: 10,062 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I sanded re-spray off of space on inner pass. fender where number should be stamped, right down thru grey primer to bare metal & can see no sign or trace of any numbers. This may very well be a replacement fender. Just to be perfectly clear that stamp is on the inner wheel housing not the fender. Fender's were commonly replaced due to shunts but to replace the whole inner wheel house where the VIN stamp is located is less common & a pretty big job. More likely sectioned so you might need to expand your sanding to find any evidence of welding seams |
Lo-Fi Version | Time is now: 16th May 2024 - 11:03 PM |
