vin question, two number plates missing |
drifter914 |
Jun 29 2019, 05:27 PM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
Hi Guys... I bought a '74 914 with Indiana title showing the same vin as on the windshield frame tag & the tag riveted to passenger side front wheelwell. Both of these tags are easily replaceable.
The vin sticker inside driver door jamb is missing & the number stamped on top of pass. wheelwell has been ground off ... gone ! The number stamped inside rear trunk floor on pass. side is a different number & is only 7 digits. Should this number be the same as vin ? So... so do I have a vin swap situation here... ? I can understand maybe removing the sticker inside the driver door jamb for a repaint, but to grind off the number stamped into the metal on top of front pass. wheelwell seems very intentional & for what purpose ? Is the number stamped inside rear trunk floor supposed to match vin on title ? Not completely sure what I have here... possible vin swap ? I feel the number in rear trunk floor may be key to solution. (IMG:style_emoticons/default/confused24.gif) What say you ... Thanks... Terry in Az |
Jim C |
Oct 21 2019, 12:26 PM
Member Group: Members Posts: 190 Joined: 11-July 19 From: Texas Member No.: 23,294 Region Association: Southwest Region |
I can't find a chassis number in the rear trunk of my 1976 914 2.0. It doesn't look like the trunk floor was replaced and there is no rust elsewhere that makes this likely. Thoughts?
dr914@autoatlanta.com |
Oct 21 2019, 12:54 PM
914 Guru Group: Members Posts: 7,858 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I can't find a chassis number in the rear trunk of my 1976 914 2.0. It doesn't look like the trunk floor was replaced and there is no rust elsewhere that makes this likely. Thoughts? I have actually never seen a Karmann number stamped into the rear trunk of any 75 76 model |
Jim C |
Oct 21 2019, 01:04 PM
I can't find a chassis number in the rear trunk of my 1976 914 2.0. It doesn't look like the trunk floor was replaced and there is no rust elsewhere that makes this likely. Thoughts? I have actually never seen a Karmann number stamped into the rear trunk of any 75 76 model Thanks. The info I'd seen didn't differentiate between years. I assumed all the cars were stamped in the trunk. I'll stop looking now. |
Lo-Fi Version | Time is now: 16th May 2024 - 09:01 PM |
