Found a near complete L-jet system in my cleanup !, may fit to my only FI shortblock,questions ? |
porschetub |
Jul 5 2019, 12:19 AM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Whats the going rate for a usable 1.8 AFM (0 280 200 012) as the one I have is toast ?,not worried about cleaning and servicing.
I have an good early 1.7 shortblock and have heads and 96mm B&P set to fit but will need to purchase injectors also,in real terms the case is worth very little with the cam it has and think this may be a good move for my situation,I don't know if the D-jet cam plays well with L-jet cam?,believe they do. I have sold most of my D-jet stuff now and also prefer the less complicated system with L-jet and besides I have bugger all knowledge of D-jet besides. TIA (IMG:style_emoticons/default/beerchug.gif) . |
porschetub |
Jul 19 2019, 10:39 PM
Case cleaning has taken way longer than I thought between other work but it is clean now,JB welded the oil gallery plugs ,most likely not needed but wanted to be sure ,due to poorly fitted RMS seal there was a small leak , have been checking end float,came out @ .0032 so happy with that.
Case has been split before but some fine individual has been very excessive with gasket shellac and caused BS to get rid of it @ front and rear crank seals recess's. Not 100% happy with piston pin fit so will get the rods rebushed,hooked up with a local engine shop and have found new bushes in my country. Heads are a bit of a guess really,fully rebuilt but part number 022 102 372G comes out @ 2.0 bus ,understand they are low compression but fit my 1800 barrels so something is odd. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 7th May 2024 - 12:23 AM |
