Correct fuel pump for MFI??, 2.7L with mech. injection |
Bob Wolcott |
Jun 26 2005, 07:48 PM
Member Group: Members Posts: 85 Joined: 18-May 05 From: McMinnville, OR Member No.: 4,096 |
Will the stock 914-6 fuel pump work with MFI or will I need to replace it? If so, with what?
Thanks, Bob |
sixnotfour |
Jun 26 2005, 09:23 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
You need the matching bosch or equal MFI pump.
Bosch about 400.00 flow is 125liter/hour your carb pump os 80liter/hour also pressure is .3 bar you need 1bar for MFI youll also need the MFI filter housings/cold start injector. I can use youre bosch carb pump if you dont need it anymore. |
Lo-Fi Version | Time is now: 21st May 2024 - 10:15 PM |
