Turn signals, flashers, new to me |
advman89 |
Jul 9 2019, 07:05 AM
Member Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest |
1971 914-4
New to me Starting to sort out some things. First up- turn signals. The fuse box is missing it's cover, but the second fuse from the far right is missing...and adding one in immediately shorts. So I pulled the flasher (as recommended on Rennlist before I found you guys!) And tested continutiy between #49 and left and right...nothing. The flasher isnte working. Then I noticed a newer/modern looking relay hanging out behind the fuse panel...it's operating the turn signals. My suppostionn is that they have bypassed emergency flasher? I got the turn signals working with cleaning the bulb sockets and using a little dilectic grease. Id love to get the emergency flashers operating...has anyone else elese had anything like this? Thanks in advance. |
914Sixer |
Jul 9 2019, 07:19 AM
914 Guru Group: Members Posts: 8,871 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Early cars used a different flasher than the later cars. I do not know the internal differences. Flasher shown is a solid state model. Early switches were mechanical. PET shows 914.618.303.11 for 70-72 cars. Early flashers are quite a bit larger than the late one. See if some one has a relay you can borrow to tes.
Lo-Fi Version | Time is now: 29th April 2024 - 05:25 PM |
