Stock D-jet 1,7 running wery lean but why? S O L V E D |
larss |
Jul 9 2019, 01:30 PM
Member Group: Members Posts: 428 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
Have some problems with a stock 1,7 D-jet that runs wery lean, hunts and pops in the intake, hardly running at all....reving up wery uneven and slowly.
-Engine has not been running for severeal years so there is no history to tell. -Timing triple checked 27 degrees at 3500rpm -Fuel pressure triple checked 31psi -All 4 injectors new (repro) -Trigger points checked OK -Changed to anoter MPS (which runs well in another d-jet) with no difference -Changed head temp sensor with no difference -Compression tested, even around 145psi -Points, condenser, cap, cables are new (also tested with an old set but no difference) -All injectors getting pulses, checked and injector plugs are at the correct injectors -Yes firing order is triple checked The only way to get it running quite OK is to replace the head temp sensor with a potentiometer at 3Kohms, runs quite good with that even when warm. This leads me to think that it is running w e r y lean for some reason. Any ideas? /Lars S |
JeffBowlsby |
Jul 9 2019, 01:32 PM
914 Wiring Harnesses Group: Members Posts: 8,485 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Which MPS part number do you have, does it hold vacuum and has it been previously adjusted?
larss |
Jul 9 2019, 10:51 PM
Which MPS part number do you have, does it hold vacuum and has it been previously adjusted? Thanks Jeff! Sorry but the car is not neraby so I can not check tne MPS no at the moment but both MPS we have tested holds vacuum perfectely and still have the epoxi plugs and one of the MPS is borrowed from a car which runs good. I dont know if I shall trust the new injectors flow rate beeing the same as the original yellow ones. They are bought as beeing a direct replacement however. //Lars S |
Lo-Fi Version | Time is now: 30th April 2024 - 02:14 PM |
