custom length push rods, Need a vendor |
Bruce Edge |
Jul 9 2019, 08:56 PM
Old School 914 Group: Members Posts: 63 Joined: 6-December 16 From: South Carolina Member No.: 20,646 Region Association: None |
Looking for vendor to make custom length push rods .( HD Aluminum)
Recommendation appreciated. Thanks, Bruce Edge |
VaccaRabite |
Jul 11 2019, 07:17 AM
En Garde! Group: Admin Posts: 13,440 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
As Mark said, you really don't want aluminum pushrods.
Get the cut to length CroMo rods that Chris sells. Added advantage - you can now set your valve clearance to 0. If you are rebuilding an engine, everything you can do to improve your valve train is going to add benefit to your motor. Also, when I cut mine no lathe was needed. I just cut them SLIGHTLY proud with a hack saw and then walked into my measurement with file (which also dressed the edge). Zach |
Mark Henry |
Jul 11 2019, 09:30 AM
Also, when I cut mine no lathe was needed. I just cut them SLIGHTLY proud with a hack saw and then walked into my measurement with file (which also dressed the edge). Zach Yes I've also done it this way, a trick is to paint the cut area with blue or black marker, then use a pipe cutter to make a light score line before you cut. But don't be tempted to try the pipe cutter, material is too hard and the cut isn't square. To put the end in, once you've done the cut, use two old lifters and hammer it home. |
VaccaRabite |
Jul 11 2019, 09:44 AM
Also, when I cut mine no lathe was needed. I just cut them SLIGHTLY proud with a hack saw and then walked into my measurement with file (which also dressed the edge). Zach Yes I've also done it this way, a trick is to paint the cut area with blue or black marker, then use a pipe cutter to make a light score line before you cut. But don't be tempted to try the pipe cutter, material is too hard and the cut isn't square. To put the end in, once you've done the cut, use two old lifters and hammer it home. IIRC that exactly how I did most of mine. Starting them with the pipe cutter to get the scored line which let the saw track a lot more precisely. Made the file work easier too. Zach |
Lo-Fi Version | Time is now: 7th May 2024 - 01:55 PM |
