Calling all 3.2 converters, Looking for data about KEP kit |
worn |
Jul 12 2019, 04:01 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Edit: what I was looking for was some sort of response, yeah or nay about clutch cable trave.. My experience with a 2002 era kit (bought years later from someone who decided not to install it) has been that disengagement only occurs at very last end of pedal travel. This with little if any pedal free play. The instructions I got from KEP told me that the clutch would require “1.5 inches of cable travel”. The stock 914 pedal cluster isn’t up to such hurdles - less than an inch in my experience.
I am hoping to hear from others with a 3.2 (the lucky) if they had been able to plug and play or if they too had difficulties generating enough cable travel. I think I have a simple fix, but also am worried that I have made some dumb-ass mistake in assembly. Thanks, Warren Hi folks. I love my 3.2 engine in the 72 914 but am having clutch issues. I bought the conversion package from an enthusiast who decided not to complete their project. The ring works perfectly with the starter and i have no real problems except tgat i am grinding gears going into first and reverse. The clutch kit directions date to 2002 and state that there should be 1.5 inches of clutch cable travel. This may explain why when i have taken up all of the pedal free play i still cannot quite completely disengage the clutch with the pedal down. It almost works: i can get into first if i shift while rolling. I can get into reverse if i select it before turning on the motor. I find that the bell crank at the pedal moves a little less than 0.75 inches, and the trunnion at the end of the cable moves by the same amount. This is a far cry from an inch and a half. I can make some work arounds, but figure i probably have made a mistake: no one else seems to be having this trouble. Help! (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/sad.gif) |
lierofox |
Jul 12 2019, 04:10 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
I ended up welding extra material to the lever arm at the pedal assembly on my 914 to make it longer and give it more throw, space was pretty tight with the throttle linkage in the tunnel. The clutch pedal is now a bit heavier due to having less mechanical advantage, but it's a lot more movement in the cable.
worn |
Jul 12 2019, 09:44 PM
I ended up welding extra material to the lever arm at the pedal assembly on my 914 to make it longer and give it more throw, space was pretty tight with the throttle linkage in the tunnel. The clutch pedal is now a bit heavier due to having less mechanical advantage, but it's a lot more movement in the cable. Thanks. I looked at that and space between the clutch and throttle cables look very tight indeed. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:33 PM |
