Early Seat Belt Resto |
db9146 |
Jul 14 2019, 06:12 AM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I want to restore a spare set of early (1970) seat belts to improve their appearance and also to make them easier to adjust since they are not retractable. It seems that there are different finishes on the belt mounting ends and the belt latches that are a more natural metal appearance as opposed to the chrome on the adjusters and the belt latching tabs.
I have taken one latch apart and cleaned it up via bead-blasting, a vibratory cleaner/polisher, and some elbow grease with metal polish and a brass bristle brush (you can see how it started off). The finish of the latches (once the covers are removed) and the anchoring ends appears to be some sort of a flat metal finish. Does anyone know what finish it is? Or how to achieve it? I think the chrome will clean up well enough once the belts are removed and the chrome can be cleaned/polished a little. Has anyone sent out an early set of belts to a restorer and been happy with the results? Who did you use? What was the cost? Any pics? What about the dated fabric tags stitched to the belts? Anyone have a source on these? Comments or suggestions would be appreciated. |
rgalla9146 |
Jul 15 2019, 09:06 PM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Is there a source for the sewn on white cloth labels ? The ones that have the
part number and the date ? |
Biggles |
Jul 17 2019, 02:31 PM
Member Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
Is there a source for the sewn on white cloth labels ? The ones that have the part number and the date ? Yes I got a load made. Very slightly wider than OEM but otherwise the same. Can post some if required. Say £10 a pair + postage. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 04:54 AM |
