How to check Webers for throttle shaft leaks? |
Tdskip |
Jul 14 2019, 05:46 PM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hi guys - hope everyone’s had a good weekend so far.
I am about to rebuilt a set of Weber’s which will be a first for me. I’ve rebuild quite a few carb on the British cars I cut my teeth on, so am at least familiar with carbs in general. With the British cars all you need to do is see if can wiggle the throttle shaft to see if you have any play, if you do they need to be addressed. Is there a similar test on the Weber’s I should be checking - I assume so. False air is no fun. Thanks! |
IronHillRestorations |
Jul 14 2019, 06:28 PM
I don't know how to bench test, but on a running car you can spray carb cleaner and if it runs worse you've got leakage. You can also glob bearing grease on the suspect leak, and if it runs richer, you also have leakage.
Tdskip |
Jul 14 2019, 06:41 PM
I don't know how to bench test, but on a running car you can spray carb cleaner and if it runs worse you've got leakage. You can also glob bearing grease on the suspect leak, and if it runs richer, you also have leakage. Hi Perry! Thanks for the response. Pulling then back off wouldn’t be the end of the world, and will keep those tests in mind, but was hoping to find a way to check beforehand. I have two spare sets so can pick the better of the two if there is a difference. |
Minerva's 914 |
Jul 14 2019, 07:53 PM
Member Group: Members Posts: 378 Joined: 24-December 15 From: Chapel Hill, NC Member No.: 19,489 Region Association: South East States |
I don't know how to bench test, but on a running car you can spray carb cleaner and if it runs worse you've got leakage. You can also glob bearing grease on the suspect leak, and if it runs richer, you also have leakage. (IMG:style_emoticons/default/agree.gif) |
ValcoOscar |
Jul 14 2019, 08:22 PM
Garage Life Group: Members Posts: 2,374 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
I don't know how to bench test, but on a running car you can spray carb cleaner and if it runs worse you've got leakage. You can also glob bearing grease on the suspect leak, and if it runs richer, you also have leakage. Hey guys... Great question and answer. One to remember. (IMG:style_emoticons/default/beerchug.gif) |
914Toy |
Jul 14 2019, 09:09 PM
Senior Member Group: Members Posts: 716 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
In my case I could “jiggle” the shafts up and down on my triple throat Weber 40’s - was obvious the shafts were leaking air. Having them repaired made a huge difference to the engine performance both in smoothness at all rpm’s and power.
porschetub |
Jul 15 2019, 12:11 AM
Cost out getting the throttle shaft bushes redone,its a specialist job and is normally expensive...not DIY by any means,it's an involved process requiring special jigs and reamers.
The repair work is the big cost ,just don't get the cheapest price because you won't get what you really need. Folks doing this are thinning out I understand legend Paul Abbot is scaling back on new work these days I guess he may be retiring ? Parts Klassic (?) do them from memory and think there are a few others,good luck. |
914Toy |
Jul 15 2019, 09:08 AM
Cost out getting the throttle shaft bushes redone,its a specialist job and is normally expensive...not DIY by any means,it's an involved process requiring special jigs and reamers. The repair work is the big cost ,just don't get the cheapest price because you won't get what you really need. Folks doing this are thinning out I understand legend Paul Abbot is scaling back on new work these days I guess he may be retiring ? Parts Klassic (?) do them from memory and think there are a few others,good luck. (IMG:style_emoticons/default/agree.gif) |
rhodyguy |
Jul 15 2019, 11:36 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Inquire at Blackline Racing. Murray Utah. Ustah be Air Cooled Engineering, A.C.E.
Eric_Shea |
Jul 16 2019, 02:36 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
If they're off you can look for carbon trails on the butterfly's
type2man |
Jul 16 2019, 02:44 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
Wiggle the throttle shafts. Also while the carbs are out, shine a light on the throttle shafts to check for a bent shafts or butterflies. Other than that, just clean them and run them. Or you can upgrade to dells. They don't wear like the Webers do....and run much better.
lalee914 |
Jul 16 2019, 03:09 PM
Senior Member Group: Members Posts: 811 Joined: 13-February 13 From: Georgetown, DE Member No.: 15,521 Region Association: North East States |
Tdskip |
Jul 17 2019, 08:19 AM
Good info, thanks gentlemen.
Tdskip |
Jul 17 2019, 12:04 PM
Tdskip |
Jul 17 2019, 12:06 PM
(Dupe - sorry)
Tdskip |
Jul 17 2019, 12:07 PM
914Toy |
Jul 17 2019, 01:52 PM
While you have these accelerator pump covers off, use a medium course sandpaper on a flat surface (eg granite cabinet top) to sand the the covers flat. Tightening the four bolts over the many years can bend the bolt hole "ears".
Tdskip |
Jul 17 2019, 02:09 PM
Good tip, thanks Keith.
Lo-Fi Version | Time is now: 25th April 2024 - 09:02 PM |
