How to check Webers for throttle shaft leaks? |
Tdskip |
Jul 14 2019, 05:46 PM
Hi guys - hope everyone’s had a good weekend so far.
I am about to rebuilt a set of Weber’s which will be a first for me. I’ve rebuild quite a few carb on the British cars I cut my teeth on, so am at least familiar with carbs in general. With the British cars all you need to do is see if can wiggle the throttle shaft to see if you have any play, if you do they need to be addressed. Is there a similar test on the Weber’s I should be checking - I assume so. False air is no fun. Thanks! |
914Toy |
Jul 14 2019, 09:09 PM
Senior Member Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
In my case I could “jiggle” the shafts up and down on my triple throat Weber 40’s - was obvious the shafts were leaking air. Having them repaired made a huge difference to the engine performance both in smoothness at all rpm’s and power.
Lo-Fi Version | Time is now: 18th May 2024 - 02:00 PM |
