A different way of lowering the 914 |
type2man |
Jul 16 2019, 01:18 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
I've read almost all the threads covering the lowering of a 914. Reindexing the torsions gives you about 2 inches, raising the spindles gives you about an inch. So now you're almost at the bottom. You're at the point where the rubber inserts bottom on the struts and the ride quality suffers.
So I was wondering if anyone out there had ever considered or researched cutting the strut tube shorter and finding a shorter insert. The super beetles have this and it solves bottoming out. Just throwing this out there. Maybe someone here has done it. |
9146GUY |
Jul 16 2019, 01:42 PM
Member Group: Members Posts: 112 Joined: 29-November 15 From: Central Ohio Member No.: 19,420 Region Association: Upper MidWest |
I did this way back when Carrera shocks were using my IMSA 914-6 as a test bed. circa late 70's. We used shorter inserts that they made and shortened the shock tube.
I believe the inserts were from a 240Z but age does something to memory. It gained us about an inch. |
Lo-Fi Version | Time is now: 12th May 2024 - 11:54 AM |
