A different way of lowering the 914 |
type2man |
Jul 16 2019, 01:18 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
I've read almost all the threads covering the lowering of a 914. Reindexing the torsions gives you about 2 inches, raising the spindles gives you about an inch. So now you're almost at the bottom. You're at the point where the rubber inserts bottom on the struts and the ride quality suffers.
So I was wondering if anyone out there had ever considered or researched cutting the strut tube shorter and finding a shorter insert. The super beetles have this and it solves bottoming out. Just throwing this out there. Maybe someone here has done it. |
burton73 |
Jul 18 2019, 12:17 PM
burton73 Group: Members Posts: 3,517 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Sorry but I do not understand why for a street car that going up driveways where the lot is level with the sidewalk 10 ft. in you would want to go lower than what is easily adjustable from the front-end adjustment. At least in Los Angeles.
I have lowered my 914s and 911s for street use over the years with just the front-end adjustment over the years and they aligned and worked fine. If you want to slam them down that is different. I guess that is for race or low looks Bob B |
Lo-Fi Version | Time is now: 12th May 2024 - 07:04 PM |
