A different way of lowering the 914 |
type2man |
Jul 16 2019, 01:18 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
I've read almost all the threads covering the lowering of a 914. Reindexing the torsions gives you about 2 inches, raising the spindles gives you about an inch. So now you're almost at the bottom. You're at the point where the rubber inserts bottom on the struts and the ride quality suffers.
So I was wondering if anyone out there had ever considered or researched cutting the strut tube shorter and finding a shorter insert. The super beetles have this and it solves bottoming out. Just throwing this out there. Maybe someone here has done it. |
914forme |
Jul 18 2019, 07:28 PM
Not sure how low the original poster wants to go, or the stated purpose.
On my street driven auto-x car, I have scrapes on the RennMetal front tie downs. Which are just below the LE valance on the car. This is with a set of 19mm raised spindles, 15" wheels with 205/50 DOT-Rs. It was low, matter of fact to low in the rear that I had to raise it to get the handling back on track. New iteration the spindles got raised to fit the 17 inch wheels I would have ran, and adding camber plates and modified strut tops from Tangerine Racing, the Rear was going up 2" to raised the rear pickup points to correct the geometry back there, and the shock towers have been raised with Tangerine Racing tall kit. I never take the top off, suspension travel is more important. If it was dedicated auto-xer I would still do all the above, except raise the rear with a 3" raised pickup points. Of course the tie rods where setup with proper bump steer system in double sheer, etc... Not sure how low you really need to go, but I guess if you want just make the suspension solid do not stiffen the car, and well now you have a go kart. But you can be as low as you want to be. I would add some titanium skid plates to allow you to scrape if it is good enough for the F1 guys it is good enough for a 914. |
Lo-Fi Version | Time is now: 12th May 2024 - 08:13 AM |
