Throwing in the towel, Carburator conversion for 74 1.8 ltr |
Jul 16 2019, 09:30 PM
Resident German Group: Admin Posts: 41,609 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The point is 50 year old FI will never be as reliable as a brand new set of quality carbs and a new pointless distributor. I dis-agree. The L-Jet system was used on more than just the 914 and the system is well understood and parts are readily available. When i still had my 1.7L D-Jet i went through several months of trouble shooting and eventually merged 3 engine wiring harnesses into one good one and got the engine running as smooth as the day it came off the assembly line. I've also had a warmed over 2056 with dual carbs and an aggressive cam. It had loads of power the few times it actually ran ok, but in terms of smoothness and reliability there just is no comparison. FI all the way. Just try to start a carbed car jetted for sea level at 5000 feet up in the mountains and report back to me how much better than FI they are. (IMG:style_emoticons/default/shades.gif) |
Superhawk996 |
Jul 17 2019, 04:43 AM
914 Guru Group: Members Posts: 5,769 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I don't have a dog in the fight.
I had carbs on my 1st 914. Put an incredible number of miles on it without issues related to carbs. Ignition was usually the problem (bad points, wires, etc.). Carbs can be reliable. As others have stated FI really is the better solution . . . no doubt . . . but it comes with cost and complexity. Just look at modern vehicles. They start at -20F with no issue and modern emissions couldn't be met without FI. I'm a mechanical engineer with a background as an electronics technician that did repair down to component level (resistor, capacitors, etc.). The biggest issue I see with the original FI and with issues on this site is wiring. You guys post pictures of wiring that makes me tremble in my boots. Especially the FI & engine harness wiring. This stuff has been exposed to the heat and elements for 50 years! Bad wiring and poor grounds will cause all sorts of intermittent problems that can make you want to slit your throat. Second biggest issues is that these cars are OLD. Many of the sensors are mechanical in nature (MPS, AAR, decel valves, analog Engine Control ECU, etc). Things do wear out. Sure they can often be repaired or jury rigged but that takes time and effort. Lots of effort! I believe that IF you take the time to properly sort out these issues the stock FI will be fine. I intend to put D-jet back on my project. However, personally, if I could come up with the $$, I'd do the system below in a heartbeat. But. . . . you still have to fiddle with calibration, installation, wiring, etc. http://thedubshop.com/dual-throttle-body-f...gnition-type-4/ My personal reason for the above system is that I prefer the look of carbs and that system would at least get the FI into the digital age. |
DRPHIL914 |
Jul 17 2019, 05:58 AM
Dr. Phil Group: Members Posts: 5,764 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I don't have a dog in the fight. I had carbs on my 1st 914. Put an incredible number of miles on it without issues related to carbs. Ignition was usually the problem (bad points, wires, etc.). Carbs can be reliable. As others have stated FI really is the better solution . . . no doubt . . . but it comes with cost and complexity. Just look at modern vehicles. They start at -20F with no issue and modern emissions couldn't be met without FI. I'm a mechanical engineer with a background as an electronics technician that did repair down to component level (resistor, capacitors, etc.). The biggest issue I see with the original FI and with issues on this site is wiring. You guys post pictures of wiring that makes me tremble in my boots. Especially the FI & engine harness wiring. This stuff has been exposed to the heat and elements for 50 years! Bad wiring and poor grounds will cause all sorts of intermittent problems that can make you want to slit your throat. Second biggest issues is that these cars are OLD. Many of the sensors are mechanical in nature (MPS, AAR, decel valves, analog Engine Control ECU, etc). Things do wear out. Sure they can often be repaired or jury rigged but that takes time and effort. Lots of effort! I believe that IF you take the time to properly sort out these issues the stock FI will be fine. I intend to put D-jet back on my project. However, personally, if I could come up with the $$, I'd do the system below in a heartbeat. But. . . . you still have to fiddle with calibration, installation, wiring, etc. http://thedubshop.com/dual-throttle-body-f...gnition-type-4/ My personal reason for the above system is that I prefer the look of carbs and that system would at least get the FI into the digital age. (IMG:style_emoticons/default/agree.gif) 10 years ago this fall I bought a '75 2.0 d-jet car not running but figured we'd figure it out. I had never owned a 914 or a Porsche, but had a '69 Austin Healy 25 years before and knew I did NOT want to deal with the mess that was dual Webber carbs, and figured it was going to be a bit of a trip to sort it allout, but my first test was compression leak down and then starter fluid in the intake to see if it fired, as I had already checked and had spark at all 4 - simple - it ran , for a few seconds- took it home cleand the system, tested some components and bam! BAD MPS- and with new rebuilt MPS I was on the road-but over thenext year I proceeded to essentially replace all the smaller sensor components and vac and fuel lines , because as he said above its all OLD stuff no matter what - but I can tell you the issues ive had over the years were ususally related to some bad ground(FI grounds) or bad mechanical sensor (AR) failed CHT, what have you, but for past 5 years , trouble free and now with a 1123ignition distributor, like brand new. - most issues were wiring related and I replaced my harness with a new one with new connectors from Jeff Bowlsby , I did that fairly early in the process. I am with Sir Andy on this in the long run MPG and performance will be better , way better with FI - and I have learned a lot - Yes carbs work and can be ok , but really not more simple than FI, clogged jets , floats etc. - with that said, I had a BMW - 73 motorcycle, R90S and of course was carbs, and in MN it sat all winter , but really rarely had issue with it but I wonder what it would have been like to put FI on that? (IMG:style_emoticons/default/idea.gif) but I digress-- do what makes you happy and you can deal with but do not fear the FI! I get 30mpg with my d-jet ., you wont get that with carbs. |
dr914@autoatlanta.com |
Jul 17 2019, 07:44 AM
914 Guru Group: Members Posts: 7,832 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
George Hussey 1978 " do not remove the fuel injection". dr914 tech tips circa 1999 "do not remove the fuel injection" George Hussey 2019 "do not remove the factory fuel injection"
I'll play along... (IMG:style_emoticons/default/devil.gif) It seems the community has gone from: 1. Put carbs on - Early years when old schools couldn't figure out the FI 2. Don't put carbs on - Mid years when shade-trees dug in and became more knowledgeable than most old schools on FI systems. Parts were plentiful. They were/are correct. 3. Here and now... Here & Now, harnesses are brittle, good parts are getting harder to find and, a good FI system requires a knowledgeable tech trained in the art of 50 year old FI systems. My take is, if your system is stock and you have all of the components, it may be worth a shot at saving it. That said, you can easily spend thou$and$ with MPS rebuild, TPS Rebuilds, leaks and bad wiring (a $500.00 harness from Jeff B. would be an EXTREMELY wise investment). I guess my point is, I feel carbs can be a viable alternative as we are beginning to run out of stock FI resources. Good parts are just getting harder and harder to find and, it's an old system. ***They (carbs) will make less power when run on FI cams*** As you move forward plan on a motor rebuild with a substantial cam to take advantage of all that carbs can offer. If you're considering an engine rebuild, I would go 2258 with the new stroker cranks out there and run either carbs or EFI the likes of The Dub Shop's Type 4 MicroSquirt system. An EFI system on a motor like that will change your world. So... *Try to keep it alive if you can. *Don't feel bad if you have to go carbs but, look to the future and make sure you have your eye on the proper cam for the motor eventually so you can take advantage of them. *Did I say look to the future? Modern EFI systems can be almost plug and play these days and they will reward you in technological leaps and bounds. It's amazing. |
Jul 17 2019, 07:50 AM
afc l jetronic fuel injection is MUCH simpler than mpc d jetronic fuel injection and is very easy to troubleshoot and repair. Parts are actually inexpensive for this car
downrange |
Jul 17 2019, 08:21 AM
Newbie Group: Members Posts: 22 Joined: 1-January 18 From: Pennsylvania Member No.: 21,747 Region Association: MidAtlantic Region |
downrange |
Jul 17 2019, 08:25 AM
downrange |
Jul 17 2019, 08:54 AM
don't do it! Call me personally for tech advice and we can work through it!! I am on my last nerve trying to get my 74 1.8 ltr L Jetronic fuel injected car started. Bypassed the seatbelt interlock to get the starter to work. Hot wired the fuel pump to get it working and still no go. I am considering a carburetor conversion and see that Redline has a few kits. The dual carbs system has no choke and the single carb with electric choke has some distance from the cylinder heads. Anyone have any success they could share? Thanks for the offer. Will do before performing the operation. |
type2man |
Jul 17 2019, 11:36 AM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
To the original poster, how long has the car sat before this problem happened? Or did this just happen from one day to the next. Also another thing to take into consideration is how good your mechanical abilities are? Fuel injection can get a bit complex, but so can adjusting a set of carbs to run properly. If you don't have great mechanical abilities and have to rely on someone to install the carbs or troubleshoot the FI, things can get expensive quickly....
Rav914 |
Jul 18 2019, 04:26 PM
All-weather fan Group: Members Posts: 738 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
I'll dog pile on this one too!
I have a 1.8 (1.9 really) L-jet car. I went from: 1. Stock motor and FI to, 2. 1911 with Webers to, 3. 1911 with L-jet. I prefer the L-jet to carbs any day. Much smoother idle and acceleration and better gas mileage. I feel like I lost a little bit of power, but it's what came with the car, so I feel it's worth any trouble it brings. "Bosch Fuel Injection and Engine Management", by C Probst is a stellar book. Highly recommend. |
orthobiz |
Jul 18 2019, 05:37 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I've had three major bad running problems with my 1.8 1974 L-jet:
One was a stuck flapper in the air intake thingy. One was a bad dual relay: car would run poorly for 30-40 seconds and then would konk out. One was a fried engine harness. Each problem fixed with replacement parts, a "good" used harness, a rebuilt air thingy and a new dual relay. Car running smoothly now. Contact Tim about L-jet, he's an accessible expert. PM sent. Paul |
downrange |
Jul 19 2019, 10:40 AM
QUOTE That's why FI died some 40 years ago and nobody uses it anymore. Carbs rule today's automotive landscape for a reason! (IMG:style_emoticons/default/rolleyes.gif) You misunderstand the point. I don’t see anyone trying to make an argument that carbs are better than FI. Bosch were ahead of their time with the systems they made for the 914 and FI is superior to carbs. The point is 50 year old FI will never be as reliable as a brand new set of quality carbs and a new pointless distributor. Can you give me some info on the pointless distributor. |
mitchdiego1 |
Jul 19 2019, 11:00 AM
Newbie Group: Members Posts: 42 Joined: 19-May 19 From: oceanside ca Member No.: 23,145 Region Association: Southern California |
QUOTE That's why FI died some 40 years ago and nobody uses it anymore. Carbs rule today's automotive landscape for a reason! (IMG:style_emoticons/default/rolleyes.gif) You misunderstand the point. I don’t see anyone trying to make an argument that carbs are better than FI. Bosch were ahead of their time with the systems they made for the 914 and FI is superior to carbs. The point is 50 year old FI will never be as reliable as a brand new set of quality carbs and a new pointless distributor. Can you give me some info on the pointless distributor. I have a 1976 914 non cat and I put a Pertronix Ignitor Electronic Ignition in my car just two days ago and it was like night and day the difference it made. "Djet" |
jdamiano |
Jul 19 2019, 04:29 PM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
QUOTE That's why FI died some 40 years ago and nobody uses it anymore. Carbs rule today's automotive landscape for a reason! (IMG:style_emoticons/default/rolleyes.gif) You misunderstand the point. I don’t see anyone trying to make an argument that carbs are better than FI. Bosch were ahead of their time with the systems they made for the 914 and FI is superior to carbs. The point is 50 year old FI will never be as reliable as a brand new set of quality carbs and a new pointless distributor. Can you give me some info on the pointless distributor. I run this Pertronix D186604 with their Flamethrower coil on my 2.0 with the Redline Weber dual 40 kit. I’m very happy with the set up. You will need a new fuel pump and it’s a good time for new fuel lines and filters. |
JamesM |
Jul 22 2019, 04:47 AM
Senior Member Group: Members Posts: 1,894 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I'd be all for converting it to a current FI setup but nobody wants to spend that kind of cash when carbs are $500 I would (and have) save that $500 for injection every single time. Though depending on what you are starting out with you can do modern injection for under $500 if you know what you are doing. Even the best running carbs are still a compromise. Why compromise? Here is the rub though, from what I have seen, the learning curve for most people for a Megasquirt based system is pretty steep, I would say even steeper than figuring out l-jet/d-jet. If you have a stock motor and a complete injection system already, unless it is cost prohibitive to repair or you are worried about long term reliability I would stick with the l-jet. |
housepumpinpc |
Jul 28 2019, 07:23 PM
Give me time... I'll fix it eventually. Group: Members Posts: 31 Joined: 9-May 14 From: Chicago,Illinois Member No.: 17,323 Region Association: Upper MidWest |
You can find the factory workshop manual for the 914/4 fuel injection system and some manuals from Bosch for both the D and K jetronic FI systems here: http://p914-6info.net/Manuals.htm Hope this helps. Thank you!!! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 2nd May 2024 - 12:59 PM |
