Do I care that these emulsion tubes look scuzzy? |
Tdskip |
Jul 16 2019, 09:07 PM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hi guys - dogging into the dual Weber’s for the 2.0L engine. I am a total Weber newbie so thanks and advance for being patient
The car these came off apparently sat for a while and the tubes need to be soaked in thoroughly cleaned, but is long as all the passageways are open and clear I don’t really care what they look like, do I? The tips are both stamped 120. Thanks! Attached thumbnail(s) |
bigkensteele |
Jul 16 2019, 09:26 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
They are relatively cheap. Just replace them (and anything else that looks sketchy).
https://www.ebay.com/str/alfa1750scarburetorspartsstore https://www.piercemanifolds.com/Default.asp |
Tdskip |
Jul 16 2019, 09:35 PM
Thanks
type2man |
Jul 16 2019, 10:32 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
If those tubes look like that, then it might be a good idea to open up the carbs and look for other corrosion. I am guessing you have 40 webers. You will more than likely need to rejet for a 2.0. 120 mains are small.
ChrisFoley |
Jul 17 2019, 05:10 AM
I am Tangerine Racing Group: Members Posts: 7,910 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Pull them apart into the 4 pieces and check the air correction size too.
The emulsion tubes are probably usable after a good ultrasonic cleaning. Should be F11. Replace the threaded holders with tall ones. They work better. Look closely inside the wells for dry deposits. Blow thru all the fuel passages to make sure none are blocked. I've had to drill out lead plugs to clear passages in a couple of really bad 40IDFs before. Those carbs had a lot of white deposits and the emulsion tube wells were so bad I had to use drill bits (by hand) to clear them. |
Tdskip |
Jul 17 2019, 06:38 AM
Thanks guys, appreciate the coaching.
These definitely need to be totally gone through. @ChrisFoley - is there a specific holder that I want? @type2man - thanks for the heads-up, will need to do some searching on recommended combinations. |
ChrisFoley |
Jul 17 2019, 08:16 AM
Lo-Fi Version | Time is now: 28th April 2024 - 07:14 AM |
