Do I care that these emulsion tubes look scuzzy? |
Tdskip |
Jul 16 2019, 09:07 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hi guys - dogging into the dual Weber’s for the 2.0L engine. I am a total Weber newbie so thanks and advance for being patient
The car these came off apparently sat for a while and the tubes need to be soaked in thoroughly cleaned, but is long as all the passageways are open and clear I don’t really care what they look like, do I? The tips are both stamped 120. Thanks! Attached thumbnail(s) |
ChrisFoley |
Jul 17 2019, 05:10 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Pull them apart into the 4 pieces and check the air correction size too.
The emulsion tubes are probably usable after a good ultrasonic cleaning. Should be F11. Replace the threaded holders with tall ones. They work better. Look closely inside the wells for dry deposits. Blow thru all the fuel passages to make sure none are blocked. I've had to drill out lead plugs to clear passages in a couple of really bad 40IDFs before. Those carbs had a lot of white deposits and the emulsion tube wells were so bad I had to use drill bits (by hand) to clear them. |
Lo-Fi Version | Time is now: 13th May 2024 - 09:45 AM |
