noisy door check straps ! |
63acornwall |
Jul 17 2019, 09:29 AM
Member Group: Members Posts: 53 Joined: 24-January 19 From: London , UK Member No.: 22,823 Region Association: None |
How easy is it to fix noisy door check straps , as door opens the strap moves and clicks before the door fully opened . Have not taken door liner off to look as the car is not mine yet !
914Sixer |
Jul 17 2019, 11:13 AM
914 Guru Group: Members Posts: 8,871 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Been covered recently. 99% sure your hole in door strap is worn out and or the pin in door is also worn out. 914Rubber makes both the oversize pin and the door repair kit. Best to do both.
Firstcar |
Jul 17 2019, 12:53 PM
Obsessive amateur mechanic Group: Members Posts: 98 Joined: 17-March 11 From: MA -South Shore Member No.: 12,831 Region Association: North East States |
Just be forewarned that the 914R oversized pin will not fit in an unworn door jamb bracket and the 914R stay’s oversized hole will still snap with a stock pin. So you’ll need to either enlarge the door jamb bracket pin holes to fit 914R parts or find a used non “ovaled” door stay to use with your stock pins
Larmo63 |
Jul 17 2019, 06:13 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I couldn't use the 914 Rubber pins either. They are too big and started to bend the strap ears.
I'd rather live with the snap than break my car. |
914Sixer |
Jul 17 2019, 08:52 PM
Sounds like we need to send feedback to Mark at 914Rubber and let him know there is a problem.
whitetwinturbo |
Jul 17 2019, 09:41 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
dcheek |
Jul 18 2019, 08:03 AM
Senior Member Group: Members Posts: 691 Joined: 30-May 06 From: Westfield, New Jersey Member No.: 6,103 |
Maybe a bushing in the door jam bracket made of brass that would accept the standard pin would solve the problem??
Dave |
raynekat |
Jul 18 2019, 07:44 PM
Advanced Member Group: Members Posts: 2,154 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Basically, you need this.
A perfectly round hole in both the door stay arm and the receiver that's on the car. Both need to be the same size hole. And the pin needs to fit tight without any slop in both the arm and the receiver. Absent any of the above, and you'll have a noisy door stay mechanism. |
SirAndy |
Jul 18 2019, 07:48 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Sounds like we need to send feedback to Mark at 914Rubber and let him know there is a problem. @Mikey914 |
North Coast Jim |
Jul 19 2019, 07:18 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Having machined up SS stops. Since car body has near perfect std hole for the pin we will drill these new stops with the same sized hole. Will also use std pins checked for dia. Should stop the annoying clicking.
Mikey914 |
Jul 20 2019, 02:04 PM
The rubber man Group: Members Posts: 12,641 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We made thes originally for my car. When i checked the size i didn't want it to be too loose. As we would have the same popping sound as the slack was sprung forward. Easy enough to take sone off for a perfect hole. Only problem is you will nedd to know if yours is perfect.
Ill turn some down whats actual perfect size? |
Lo-Fi Version | Time is now: 30th April 2024 - 08:00 AM |
