911/914-6 oil breather braided hose. |
mb911 |
Jul 19 2019, 04:33 PM
914 Guru Group: Members Posts: 6,814 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Does anyone know where to buy this hose in bulk for a 914-6 conversion?? Anyone Want to go in on a length?
worn |
Jul 19 2019, 05:35 PM
can't remember Group: Members Posts: 3,148 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Does anyone know where to buy this hose in bulk for a 914-6 conversion?? Anyone Want to go in on a length? Are you attaching it to the port at the top of the case? I have always wondered why it appears to be set up for a bayonet fitting. In the end I drilled and tapped it for a barbed fitting. I am using braided hose now (the horror) after my attempt at ss braided hose with an an fitting didn’t work out. What tubing are you considering? |
worn |
Jul 19 2019, 05:36 PM
Does anyone know where to buy this hose in bulk for a 914-6 conversion?? Anyone Want to go in on a length? Are you attaching it to the port at the top of the case? I have always wondered why it appears to be set up for a bayonet fitting. In the end I drilled and tapped it for a barbed fitting. I am using braided hose now (the horror) after my attempt at ss braided hose with an an fitting didn’t work out. What tubing are you considering? P.s. I have an oil trap plumbed into this line and it seems to work pretty well. |
mepstein |
Jul 19 2019, 05:51 PM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
914forme |
Jul 19 2019, 06:35 PM
@MB911 Ben I would be interested in a piece if you find some in bulk.
mb911 |
Jul 19 2019, 06:56 PM
I know someone knows what it is bulk.. Was it green stripe something?
@worn it was always just clamped on with a worm gear clamp.. @MarkHenry I thought you had mentioned something in the past as an option.. |
mepstein |
Jul 19 2019, 07:15 PM
I can call the shop on monday and get the info. I know the last time I ordered it, it was a 10-12 foot length +/-. I don't remember the price.
IronHillRestorations |
Jul 19 2019, 07:55 PM
I. I. R. C. Group: Members Posts: 6,714 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've seen some cloth braid hose at my NAPA that looks very close. I can check size and post
PanelBilly |
Jul 20 2019, 08:57 AM
914 Guru Group: Members Posts: 5,799 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I got mine from a hose and fitting supplier locally. It doesn’t look OEM as it’s a smooth grey surface but it doesn’t break down with the hot oil.
dr914@autoatlanta.com |
Jul 20 2019, 08:59 AM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
mb911 |
Jul 20 2019, 01:16 PM
mepstein |
Jul 20 2019, 01:37 PM
yes here Does anyone know where to buy this hose in bulk for a 914-6 conversion?? Anyone Want to go in on a length? Part number?? Doesnt come up in a search.. porsche 000 043 205 16 It looks like Pelican has it in 3 different price ranges $15-70 depending on brand. https://www.pelicanparts.com/cgi-bin/ksearc...=000+043+205+16 @914forme @MB911 |
mb911 |
Jul 20 2019, 02:15 PM
The problem is it needs to be longer for a 914-6..
mepstein |
Jul 20 2019, 02:40 PM
mb911 |
Jul 20 2019, 03:31 PM
Ok great..
Jul 21 2019, 08:16 AM
GeorgeRud |
Jul 21 2019, 11:22 AM
I think Aircraft Spruce carries the breather hose (with the braided covering) by the foot if you can’t find a bulk source.
jkb944t |
Jul 22 2019, 11:02 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
Patrick Motorsports has it for $35.00
https://patrickmotorsports.com/products/har...4a1b6&_ss=r Jeff B |
SirAndy |
Jul 22 2019, 11:08 AM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
If you don't need to stay stock, this green hose was cheap. I cut it to length and used it for both the crankcase breather and puke bottle.
(IMG:http://www.914world.com/bbs2/uploads/post-179-1202450792_thumb.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-179-1202450158_thumb.jpg) |
Jul 22 2019, 11:31 AM
RSIC2842000. 24.26 per meter, Ben
Lo-Fi Version | Time is now: 27th April 2024 - 10:28 AM |
