911/914-6 oil breather braided hose. |
mb911 |
Jul 19 2019, 04:33 PM
914 Guru Group: Members Posts: 6,849 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Does anyone know where to buy this hose in bulk for a 914-6 conversion?? Anyone Want to go in on a length?
worn |
Jul 19 2019, 05:35 PM
can't remember Group: Members Posts: 3,153 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Does anyone know where to buy this hose in bulk for a 914-6 conversion?? Anyone Want to go in on a length? Are you attaching it to the port at the top of the case? I have always wondered why it appears to be set up for a bayonet fitting. In the end I drilled and tapped it for a barbed fitting. I am using braided hose now (the horror) after my attempt at ss braided hose with an an fitting didn’t work out. What tubing are you considering? |
worn |
Jul 19 2019, 05:36 PM
Does anyone know where to buy this hose in bulk for a 914-6 conversion?? Anyone Want to go in on a length? Are you attaching it to the port at the top of the case? I have always wondered why it appears to be set up for a bayonet fitting. In the end I drilled and tapped it for a barbed fitting. I am using braided hose now (the horror) after my attempt at ss braided hose with an an fitting didn’t work out. What tubing are you considering? P.s. I have an oil trap plumbed into this line and it seems to work pretty well. |
Lo-Fi Version | Time is now: 13th May 2024 - 01:36 PM |
