Recommendations for a hot day |
Grosbard |
Jul 19 2019, 07:39 PM
Member Group: Members Posts: 88 Joined: 29-September 09 From: Pasadena, CA Member No.: 10,862 Region Association: Southern California |
Hi all,
Temperatures here will be 100 degrees this weekend. I'm planning a drive tomorrow, so I would like to ask you guys for recommendations for keeping the engine from getting too hot. i.e. Not improvements to make for the future (I have a plan for that already), but just tips and suggestions to improve things for tomorrow. 1. My thought is as long as I'm willing to pull over at a rest area whenever the temperatures get high, and turn the car off and let it rest for 20 minutes or so, I'm thinking I should be fine. Am I correct in saying that or is 20 minutes not nearly enough for getting temps down an appreciable amount? 2. What would you say is the ideal RPM for max cooling? On the highways here, I can sometimes get as low as 2400 RPM in 5th gear while driving the speed limit. I suspect that 2400 RPM is too low for optimum fan cooling - although it also generates less heat than a higher RPM, so the question is where is the tradeoff optimal point of RPM. Thanks in advance! |
mepstein |
Jul 19 2019, 07:50 PM
914-6 GT in waiting Group: Members Posts: 19,264 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
3-3.5K. If you are falling below 3k, shift to 4th. Unless you are going downhill.
I wouldn’t stop and pull over. Car will heat soak and may be hard to start. |
Grosbard |
Jul 19 2019, 07:53 PM
3-3.5K. If you are falling below 3k, shift to 4th. I wouldn’t stop and pull over. Car will heat soak and may be hard to start. @mepstein I forgot to mention, one major thing I'm worried about is traffic getting very heavy which means I could be stuck in stop and go traffic for 30 minutes or so. I'm thinking in this case pulling over is the right solution. Do you agree? |
Lo-Fi Version | Time is now: 13th May 2024 - 08:24 AM |
