Heater flapper Valve, Connecting the pull wire.... |
jim_hoyland |
Jul 21 2019, 04:48 PM
Get that VIN ? Group: Members Posts: 9,303 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I took the flapper valve out. Fixed it, but I'm having a problem reattaching the pull wire to the barrel bolt; is there a trick to getting The bolt and wire lined up ?
Jul 21 2019, 04:55 PM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Jam it open so you get some slack for the cable. Once you get it attached, make sure the valve closes all the way.
IronHillRestorations |
Jul 21 2019, 05:18 PM
Make sure you've got the jamb nut backed out enough to get the swaged end in the barrel nut. I've also seen hickeys on the ends that made it hard to get in the barrel nut.
Lo-Fi Version | Time is now: 21st May 2024 - 07:41 AM |
