Main Targa Seal Replacement, installing new seal |
zfisher6164 |
Jul 22 2019, 09:24 AM
Newbie Group: Members Posts: 41 Joined: 19-January 19 From: California Member No.: 22,809 Region Association: None |
I was not looking forward to changing the targa seal but it really was not that bad.
Lots of silicone grease and a small plastic putty knife so you do not scratch paint. Removal is easy. For the install I put a lot of the silicone grease in the right door channel and slid one side all the way down then pushed the outside channel in with the putty knife. The top curve of the door seal takes the most work. The top part you extend across the top and hit it in with your palm so the metal part grabs the metal flange of the window. Repeat on the other window side. It is greasy but easy to clean and the new seal is much tighter on the top and looks better |
914pipe |
Jul 25 2019, 11:08 PM
Say......TEEEEEEEN!!!!! Group: Members Posts: 346 Joined: 31-July 04 From: Puerto Rico, now NC Member No.: 2,422 Region Association: South East States |
I was just doing this right now and I'm having problem to seat the top part on the metal gasket you mentioned.... Are you using the one from 914rubber?
Did you also used silicone grease while installing the top section? Every time that it looks like it is in place it just fall back.... Was even considering glue... Here are some pics on mine.... |
zfisher6164 |
Jul 28 2019, 02:43 PM
I was just doing this right now and I'm having problem to seat the top part on the metal gasket you mentioned.... Are you using the one from 914rubber? Did you also used silicone grease while installing the top section? Every time that it looks like it is in place it just fall back.... Was even considering glue... Here are some pics on mine.... I got mine from auto atlanta amd it had metal clios in the rubber that must be pushed on the metal, I hit it with the palm of my hand |
Lo-Fi Version | Time is now: 4th May 2024 - 03:06 AM |
