Main Targa Seal Replacement, installing new seal |
zfisher6164 |
Jul 22 2019, 09:24 AM
Newbie Group: Members Posts: 41 Joined: 19-January 19 From: California Member No.: 22,809 Region Association: None |
I was not looking forward to changing the targa seal but it really was not that bad.
Lots of silicone grease and a small plastic putty knife so you do not scratch paint. Removal is easy. For the install I put a lot of the silicone grease in the right door channel and slid one side all the way down then pushed the outside channel in with the putty knife. The top curve of the door seal takes the most work. The top part you extend across the top and hit it in with your palm so the metal part grabs the metal flange of the window. Repeat on the other window side. It is greasy but easy to clean and the new seal is much tighter on the top and looks better |
Mikey914 |
Jul 26 2019, 11:12 AM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Possible you have an earlier version we did. The new ones we have coextruded the clip into the rubber so our tolerances are tight and consistent. The old ones you can pinch the clip by applying pressure to close some of the gap. The problem was that the manufacturing tolerance was +/- .060, but again they can be manipulated open or closed easily.
Also 3M weather-strip adhesive can be used and easily removed later as it will stay gummy if you go that route. Happy to trade for a new one if you want to exchange. (IMG:style_emoticons/default/biggrin.gif) Mark |
JamesM |
Jul 29 2019, 05:03 AM
Senior Member Group: Members Posts: 1,895 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Well that explains why I have never been able to get the top portion of mine to stay on! Thought it was just me.
Possible you have an earlier version we did. The new ones we have coextruded the clip into the rubber so our tolerances are tight and consistent. The old ones you can pinch the clip by applying pressure to close some of the gap. The problem was that the manufacturing tolerance was +/- .060, but again they can be manipulated open or closed easily. Also 3M weather-strip adhesive can be used and easily removed later as it will stay gummy if you go that route. Happy to trade for a new one if you want to exchange. (IMG:style_emoticons/default/biggrin.gif) Mark |
Lo-Fi Version | Time is now: 4th May 2024 - 01:37 AM |
