Case to Cylinder Sealing Ring, For 102 mm Cylinders |
Mblizzard |
Jul 22 2019, 02:26 PM
914Sixer |
Jul 22 2019, 02:58 PM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Cylinder manufacturer?
dr914@autoatlanta.com |
Jul 22 2019, 03:21 PM
914 Guru Group: Members Posts: 7,810 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
JORGE rodriguez
european motorworks 13224 prairie ave hawthorne, ca 90250 |
Mblizzard |
Jul 22 2019, 04:48 PM
crash914 |
Jul 22 2019, 05:34 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Rimco in Santa Ana Ca.
80’s old school |
Jul 22 2019, 08:11 PM
Member Group: Members Posts: 79 Joined: 26-March 19 From: California Member No.: 22,994 Region Association: Southern California |
Use Indian Head Permatex. Don’t need spacers unless you are adjusting compression.
VaccaRabite |
Jul 23 2019, 07:17 AM
En Garde! Group: Admin Posts: 13,419 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Those spacers are how you set you deck height and static CR. They are not sealing rings. You do 100% need them.
Zach |
Mblizzard |
Jul 23 2019, 07:22 AM
VaccaRabite |
Jul 23 2019, 08:04 AM
Those spacers are how you set you deck height and static CR. They are not sealing rings. You do 100% need them. Zach Zach - Correct will be using them to set compression. Working with Len to cut the heads as well but just need to source the shims. Len does not have them? I would think that he would stock these for the Type4 Store. If he does not have them, European Motor Works would have them. Zach |
crash914 |
Jul 23 2019, 08:13 AM
LN also usually has some in stock.
Mblizzard |
Jul 23 2019, 08:24 AM
Those spacers are how you set you deck height and static CR. They are not sealing rings. You do 100% need them. Zach Zach - Correct will be using them to set compression. Working with Len to cut the heads as well but just need to source the shims. Len does not have them? I would think that he would stock these for the Type4 Store. If he does not have them, European Motor Works would have them. Zach Got the word from Len. Don't really need except to change compression. He will machine my heads to get the correct compression! Doesn't really get any better than that. He is also going to try to fast track my coating so I can keep the build on track! |
Mark Henry |
Jul 23 2019, 09:00 AM
I'd still do all the CR and deck height checks.
102 cylinders are the same case and head bore as 103's, so the 103 spacer works. |
Mblizzard |
Jul 23 2019, 09:03 AM
porschetub |
Jul 23 2019, 02:58 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Those spacers are how you set you deck height and static CR. They are not sealing rings. You do 100% need them. Zach (IMG:style_emoticons/default/agree.gif) ,European Motorworks only list up to 96mm fitment when I last checked. |
Lo-Fi Version | Time is now: 18th April 2024 - 06:37 PM |
