WTB a few small parts, Found some bits but need more |
porschetub |
Aug 2 2019, 01:33 AM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor.
Need; 1 x metal 3 bolt spacer behind crank fan 1 x thermostat mounting bracket ,found one online 2 x small spring steel tabs that hold the fan housing flap pivot rod. 1 x crankcase metal cover and bolt for oil strainer 1 x working or serviceable afm for 1.8 L-jet part Bosch number 0 280 200 012,must have free moving air gate. 1 x 3 pin altenator plug 1 x working thermostat, found one thanks Mike B 1 x dipstick Still looking thanks. Shipping to Portland Oregon 97203. TIA. |
Tbone425 |
Aug 2 2019, 07:19 PM
Newbie Group: Members Posts: 43 Joined: 15-August 15 From: AZ/WA Member No.: 19,065 Region Association: Southwest Region |
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor. Need; 2 x thermostat mounting brackets 2 x dizzy clamps 1 x crankcase metal cover and bolt for oil strainer 1 x working afm for 1.8 L-jet part Bosch number 0 280 200 012. Shipping to Portland Oregon 97203. TIA. I have an ....020 afm no ide if it will work, but you can have it if you think it will. |
Lo-Fi Version | Time is now: 6th May 2024 - 10:16 AM |
