WTB a few small parts, Found some bits but need more |
porschetub |
Aug 2 2019, 01:33 AM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor.
Need; 1 x metal 3 bolt spacer behind crank fan 1 x thermostat mounting bracket ,found one online 2 x small spring steel tabs that hold the fan housing flap pivot rod. 1 x crankcase metal cover and bolt for oil strainer 1 x working or serviceable afm for 1.8 L-jet part Bosch number 0 280 200 012,must have free moving air gate. 1 x 3 pin altenator plug 1 x working thermostat, found one thanks Mike B 1 x dipstick Still looking thanks. Shipping to Portland Oregon 97203. TIA. |
porschetub |
Aug 13 2019, 02:10 PM
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor. Need; 1 x metal 3 bolt spacer behind fan 2 x thermostat mounting brackets 3 x small spring steel tabs that hold the fan housing flap pivot rod 1 x crankcase metal cover and bolt for oil strainer 1 x working afm for 1.8 L-jet part Bosch number 0 280 200 012. 1 x working thermostat (yes I know),a T1 original would do. Shipping to Portland Oregon 97203. TIA. Bump |
Dominic |
Aug 13 2019, 06:49 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
I should have the following parts, but I will need a few days to find all of them:
1 x metal 3 bolt spacer behind fan 2 x thermostat mounting brackets (I know I have at least one) 1 x crankcase metal cover and bolt for oil strainer 1 x working thermostat (I have a T1 thermostat) Thanks, Dominic |
Lo-Fi Version | Time is now: 6th May 2024 - 05:16 AM |
