WTB a few small parts, Found some bits but need more |
porschetub |
Aug 2 2019, 01:33 AM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor.
Need; 1 x metal 3 bolt spacer behind crank fan 1 x thermostat mounting bracket ,found one online 2 x small spring steel tabs that hold the fan housing flap pivot rod. 1 x crankcase metal cover and bolt for oil strainer 1 x working or serviceable afm for 1.8 L-jet part Bosch number 0 280 200 012,must have free moving air gate. 1 x 3 pin altenator plug 1 x working thermostat, found one thanks Mike B 1 x dipstick Still looking thanks. Shipping to Portland Oregon 97203. TIA. |
Tbone425 |
Aug 2 2019, 07:19 PM
Newbie Group: Members Posts: 43 Joined: 15-August 15 From: AZ/WA Member No.: 19,065 Region Association: Southwest Region |
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor. Need; 2 x thermostat mounting brackets 2 x dizzy clamps 1 x crankcase metal cover and bolt for oil strainer 1 x working afm for 1.8 L-jet part Bosch number 0 280 200 012. Shipping to Portland Oregon 97203. TIA. I have an ....020 afm no ide if it will work, but you can have it if you think it will. |
porschetub |
Aug 14 2019, 05:11 PM
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor. Need; 2 x thermostat mounting brackets 2 x dizzy clamps 1 x crankcase metal cover and bolt for oil strainer 1 x working afm for 1.8 L-jet part Bosch number 0 280 200 012. Shipping to Portland Oregon 97203. TIA. I have an ....020 afm no ide if it will work, but you can have it if you think it will. Still keen to sell the AFM if you still have it?,cheers. |
Lo-Fi Version | Time is now: 6th May 2024 - 06:46 AM |
