Engine loses power, dies, but restarts in a minute, Diagnosis help please? |
SteveL |
Aug 4 2019, 04:58 PM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
Happens when idling or driving. After 5-10 minutes, the engine loses all power, stepping on gas pedal does nothing. Engine dies. Restarts like nothing in wrong in 10 to 60 seconds and runs great for another 10 minutes.
74 1.8 L-Jet. Bosch 2 port updated fuel pump. Just getting it back on the road after being under a cover for 3 years. It had old gas, which I drained and replaced. New fuel filter after new fuel. The fuel pump was replaced 4 years ago, but only about 1000 miles on it. Old gas was, however pumped through it. I just replaced the fuel filter again, thinking it might be clogging up from the lines being rinsed with the new gas, but it made no difference. Ideas Please?? (IMG:style_emoticons/default/confused24.gif) |
wonkipop |
Jan 22 2022, 04:01 PM
Advanced Member Group: Members Posts: 4,297 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
9 to 10 it will be fuel delivery problem.
i've got a similar thing with mine but its hot weather related. i had to replace the original fuel pump (the original 3 port) with an inline. (its under the engine bay location). the inline fights for fuel in hot weather and its due to how i had to route the hoses in, combined with just enough heat radiating off engine and exhausts to cause some cavitation. goes away when its cooler weather. also only happens at the lights sitting idling when heat builds up under car, does not happen on the move. not saying your problem is this exactly, but i'll bet its fighting for fuel. and something is causing it along the fuel line track to the pump. there is a chance it is also the power to pump cutting out randomly as suggested above. i've rebuilt my original fuel pump and will be reinstalling it to get rid of the fuel line that loops just that little bit too tight to get it into the inlet side of pump. also going to shield the metal fuel lines i did to replace the original plastic ones where they exit the tunnel and travel across to the fuel pump as i think this is part of the problem but not all of the problem. hope that helps you. |
Lo-Fi Version | Time is now: 15th May 2024 - 08:54 PM |
