Need Massive Help, Case failure |
Mblizzard |
Aug 9 2019, 05:32 PM
Ok so some of you may know I am doing the build of my life.
Put the case together for checking fit all went fine everything turned great. Disassembled and found this break in the case at the cam. I have a massive amount of money in this case and it is opened for my 102s. Anyone think of if and where I can get this repaired quickly? |
mepstein |
Aug 9 2019, 05:47 PM
914-6 GT in waiting Group: Members Posts: 19,238 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Chi-town |
Aug 9 2019, 06:11 PM
If you have it welded you're still going to have to take it back to the machine shop to have it checked/honed
mb911 |
Aug 9 2019, 07:32 PM
914 Guru Group: Members Posts: 6,810 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
It looks like aluminum so most any good TIG welder can do it. I leave for Nashville mid next week so if you wanted me to get at it I would need it Tuesday so I could ship back Wednesday
Mblizzard |
Aug 9 2019, 07:40 PM
thelogo |
Aug 9 2019, 10:35 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Ok so some of you may know I am doing the build of my life. Put the case together for checking fit all went fine everything turned great. Disassembled and found this break in the case at the cam. I have a massive amount of money in this case and it is opened for my 102s. Anyone think of if and where I can get this repaired quickly? Your scaring me Maybe their is a suabru conversion in your future (Where the long block only cost a few hundred bucks) |
Larmo63 |
Aug 9 2019, 10:42 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Just do a /6 and get it over with.
90quattrocoupe |
Aug 9 2019, 10:52 PM
Member Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California |
Sorry to see this.
It can be welded up. Maybe a little extra material welded to the back side. Then have the cam bore can be rebored. Greg W. |
Valy |
Aug 10 2019, 01:41 AM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Ok so some of you may know I am doing the build of my life. Put the case together for checking fit all went fine everything turned great. Disassembled and found this break in the case at the cam. I have a massive amount of money in this case and it is opened for my 102s. Anyone think of if and where I can get this repaired quickly? It can be repaired but not cheap as you need to weld and rebore the bearing seat. But,do I see a hairline crack between the cam bearing and the left pushrod tube hole? |
Superhawk996 |
Aug 10 2019, 02:54 AM
914 Guru Group: Members Posts: 5,748 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Slow down. Desperation and trying to do anything quickly at this point will only lead to more problems.
Anything can be fixed with enough time and money. Question is do you have enough of both? Old joke is you can have only two of the three. Quick job Affordable job Quality job If you want affordable repair and a quality repair it won't be quick. Want a quick repair and don't want to spend money, it won't be quality work. (In no way am I referring to Ben - he will do quality and will do affordable to help a member I'm sure. But the machine work isn't quick) Think long and hard about trying to save this case. At a minimum you will need to line bore the cam. After welding the cam I'd closely remeasure the crank bores for deformation. Highly likely you would want to line bore the crank too in addition to the need to line bore the cam. Line boring cases is not for the faint of heart. I know it is commonly done but honestly it is hard to do it right and maintain proper dimensional relationship between crank and cam bores. Even at the factory they dealt with this by select fitting cam gears to take up any dimensional variation between crank centerline and cam centerline. Are you ready to consider rechecking the cylinder openings too after welding? After all that - a new case looks better and better. I am so sorry that you're in this situation. I can feel the pain and anguish, and I've been there before too! |
IronHillRestorations |
Aug 10 2019, 05:25 AM
I. I. R. C. Group: Members Posts: 6,714 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Easiest thing to do is get a new/different case
Mark Henry |
Aug 10 2019, 05:54 AM
Easiest thing to do is get a new/different case Aww man...that really sucks (IMG:style_emoticons/default/sad.gif) I have to agree with Perry, get another case, too high end of a build to risk on a shaky foundation. I've never done this, but as far as having an expensive fuch up building an engine BTDT. |
HAM Inc |
Aug 10 2019, 06:45 AM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
This is a terrible turn of events for Michael. I know how much this build means to him. He's been planning it for years and we've worked together on getting his heads prepped just right for the build.
I'm very sorry for you Michael. It looked like everything was coming together for you to be ready for Okteenerfest. As for a repair, I would not be worried about this low amperage weld repair distorting the main saddles or the cylinder spigot. In the hands of a talented TIG welder the heat affected zone will not be that expansive. It is possible, however, that it could distort the adjacent lifter bore. It would probably need to be reamed, though that would remain to be seen. But one thing for sure is the cam saddle would have to be re-machined. I've put a lot of thought into how to facilitate a quality repair of this case, Michael, but I keep coming up with the sad reality that it makes more sense to replace it and move on. |
Cairo94507 |
Aug 10 2019, 08:12 AM
Michael Group: Members Posts: 9,713 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
OMG! I am sorry to see that. We all know what it takes to put these cars together and I don't mean just the cash. If it were mine, I would source another case. Sorry to say that. I hope your machine shop will do you right on prepping another case. Good luck. (IMG:style_emoticons/default/beerchug.gif)
76-914 |
Aug 10 2019, 09:46 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,490 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/sad.gif) My condolences. Still trying to figure out how that happened, given your input. If it ain't one thing it's two. Hang in there. (IMG:style_emoticons/default/beerchug.gif)
Spoke |
Aug 10 2019, 09:51 AM
Jerry Group: Members Posts: 6,973 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
What a bummer. How did this happen since it you were only fitting parts?
I have a cleaned 2L case if you're interested. |
ChrisFoley |
Aug 10 2019, 10:45 AM
I am Tangerine Racing Group: Members Posts: 7,909 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I would repair it if it was mine.
Careful build-up with TIG, no use trying to weld the broken bit back on. Then hand grind/file/scrape until a custom made gauge pin barely fit through the bore - always being careful to not cut into the remaining original bore surface nearby. I wouldn't use a reamer - too much chance of removing material from the other case half. 1 hour for the weld process and another 3-4 hours of hand work. Tedious, but doable and worth it to recover the investment. |
dr914@autoatlanta.com |
Aug 10 2019, 11:00 AM
914 Guru Group: Members Posts: 7,816 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes it can be welded and align bored, c&j welding HERE does beautiful work, then Goza machine shop has all of the align bore equipment, there is hope mike!
Ok so some of you may know I am doing the build of my life. Put the case together for checking fit all went fine everything turned great. Disassembled and found this break in the case at the cam. I have a massive amount of money in this case and it is opened for my 102s. Anyone think of if and where I can get this repaired quickly? |
Porschef |
Aug 10 2019, 01:17 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
I would repair it if it was mine. Careful build-up with TIG, no use trying to weld the broken bit back on. Then hand grind/file/scrape until a custom made gauge pin barely fit through the bore - always being careful to not cut into the remaining original bore surface nearby. I wouldn't use a reamer - too much chance of removing material from the other case half. 1 hour for the weld process and another 3-4 hours of hand work. Tedious, but doable and worth it to recover the investment. Wow (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) Sorry to see this, you must be heartbroken. (IMG:style_emoticons/default/sad.gif) |
Superhawk996 |
Aug 10 2019, 02:02 PM
I see the back and forth on this thread and it is interesting for sure. I want to reiterate again how heartbreaking this is and I feel your pain. I've been lucky enough to see things from many perspectives in my career. I've been involved with a race program with corporate funding at the highest professional levels and I can say without a shadow of doubt that I've seen extremely expensive race parts scrapped for minor flaws that are seemingly insignificant. . . Just to be absolutely sure that we had the best chance of winning a race. I've also been involved in SCCA club racing and have crewed on teams that were run on nothing more than a desire to be there. Each crew member funding their own way. I've seen wrecked cars and motors rebuilt overnight with little more than bailing wire and duct tape in order to compete the next day. I completely understand Chris' perspective that it could be saved. It absolutely could. The toughest decision is to decide which end of that continuum you are going to be on. None of us can decide that. It is a deeply personal question dependent on the end goal, time, money, and resources at hand. I wish you the best in this tough decision. I am so sorry to see you go though this. (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 25th April 2024 - 11:27 AM |
