FS: 1975 1.8 (no affiliation), A good 20 footer (don't get closer) |
BENBRO02 |
Aug 10 2019, 02:24 PM
Member Group: Members Posts: 480 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region |
Upon inspection the car was full of bondo with rust coming through in some places, the dash cover fit incorrectly. It also had numerous mechanical flaws (inoperable parking brake, sticking throttle cable, inoperable directionals, 1 inoperable headlight, bad shifter bushings). Run in the opposite direction. Listed at $19,970.
Ppm2u |
Aug 10 2019, 03:26 PM
Newbie Group: Members Posts: 1 Joined: 4-August 19 From: Cincinnati Member No.: 23,344 Region Association: None |
Upon inspection the car was full of bondo with rust coming through in some places, the dash cover fit incorrectly. It also had numerous mechanical flaws (inoperable parking brake, sticking throttle cable, inoperable directionals, 1 inoperable headlight, bad shifter bushings). Run in the opposite direction. Listed at $19,970. Where is this car? |
BENBRO02 |
Aug 10 2019, 07:07 PM
Upon inspection the car was full of bondo with rust coming through in some places, the dash cover fit incorrectly. It also had numerous mechanical flaws (inoperable parking brake, sticking throttle cable, inoperable directionals, 1 inoperable headlight, bad shifter bushings). Run in the opposite direction. Listed at $19,970. Where is this car? Chantilly, Va |
bulliporker |
Aug 11 2019, 05:41 AM
Newbie Group: Members Posts: 29 Joined: 15-April 18 From: uk Member No.: 22,040 Region Association: None |
I have waited over 7 weeks for pictures of this car as was supposed to be away getting inspected and serviced they sent me over 50 pics in the end all taken from a distance non showing hell hole, battery tray or underneath car etc, no pictures of front n rear trunk area or engine bay whatsoever
bretth |
Aug 11 2019, 07:06 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Wow that's ridiculous.
BENBRO02 |
Aug 11 2019, 06:55 PM
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 18th April 2024 - 05:47 AM |
