MrLeeS |
Member ![]() ![]() Group: Members Posts: 62 Joined: 25-April 09 From: Albuquerque, NM Member No.: 10,300 Region Association: Southwest Region ![]() |
All prices plus shipping. For sale are:
JE forged 103mm pistons and cylinders for 71mm stroke 24 mm wrist pins $400 AA H beam rods with 5/16” bolts for 2.0 journal crank 24mm wrist pins stock 2.0 length $150 - sold AA 96mm pistons hypereutectic cast pistons and cylinders for 71mm stock 24 mm wrist pins. $175 - sold SLR Cams custom grind cam. See spec sheet, I used with a turbo motor very successfully. Includes matched web-cam lifters. $200 2 stock 71mm cranks both .010 under on rods and mains. Measure out in spec for use, double check with a machinist to be sure. $150 each - 1 sold 1 remains Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
MrLeeS |
103mm barrels better interior shot.
Attached thumbnail(s) ![]() |
MrLeeS |
TTT
MrLeeS |
AA Rods sold
Morph914 |
Member ![]() ![]() Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States ![]() ![]() |
Looking to build a 2056 out of my 1.7, I understand I will need a 2.0 crank and rods to accomplish this. Will one of these cranks work for what I need?
Thanks, John |
MrLeeS |
Yes either will work. I have a good used 2.0 rod set i can give you for $40 as well. They are very low mileage, weight matched and can be used without rebuilding. You’ll need pistons/cylinders and have to have your heads machined for those as well.
Looking to build a 2056 out of my 1.7, I understand I will need a 2.0 crank and rods to accomplish this. Will one of these cranks work for what I need? Thanks, John |
Morph914 |
Pm sent
jesse7flying |
Member ![]() ![]() Group: Members Posts: 137 Joined: 9-August 16 From: Burleson,TX Member No.: 20,281 Region Association: None ![]() ![]() |
PM sent for 96mm P&Cs.
MrLeeS |
96mm pistons sold 1 crank available.
I’ve listed the Je forged 103 p/c to $400. They’d cost you >$800 new, and with a new set of rings will be about as good as new. |
Lo-Fi Version | Time is now: 30th June 2025 - 07:50 PM |
