Electrical Issue After Engine Drop |
HerdofCrickets |
Aug 12 2019, 12:20 PM
Member Group: Members Posts: 68 Joined: 23-September 16 From: Overland Park, KS Member No.: 20,423 Region Association: None |
Dropped the engine last fall, had it rebuilt and we put it back in a month or so ago.
After having a little boy a few months ago, I'm finally getting a little time to get back to work on the 914. Engine itself runs great, exhaust is really rich... so I guess the carb needs adjusted a little. One issue though... no power to the dash (tach doesn't work and radio doesn't turn on). Also when I turn the key, the engine tries to turn over but only fires when you let off the key. Pretty sure I must have a wire hooked up wrong... I'll start working backwards tonight but if anyone has any ideas... that'd be fantastic! -Jon |
76-914 |
Aug 12 2019, 02:06 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,483 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Dropped the engine last fall, had it rebuilt and we put it back in a month or so ago. After having a little boy a few months ago, I'm finally getting a little time to get back to work on the 914. Engine itself runs great, exhaust is really rich... so I guess the carb needs adjusted a little. One issue though... no power to the dash (tach doesn't work and radio doesn't turn on). Also when I turn the key, the engine tries to turn over but only fires when you let off the key. Pretty sure I must have a wire hooked up wrong... I'll start working backwards tonight but if anyone has any ideas... that'd be fantastic! -Jon I had that same experience with the ignition switch. Put a new battery in and that did the trick. What kind of voltage are you seeing at the battery. Is the blk wire w/ purple stripe connected at the coil? |
Lo-Fi Version | Time is now: 18th April 2024 - 07:25 PM |
