Second ignition switch failed? |
Sprout |
Aug 12 2019, 01:28 PM
Member Group: Members Posts: 125 Joined: 5-October 18 From: Kansas City Member No.: 22,544 Region Association: Upper MidWest |
A little guidance, please...I've replaced the ignition switch in my '73 1.7 FI twice now with Meistersatz parts, and the car is dead again. Has only been started a couple dozen times between these two switches. When I turn the key, I have lights on the dash and can hear the fuel pump engage, but the engine does not crank. Battery is at 12.5 and just installed a reman Bosch starter/solenoid. It can be push-started.
From what I've read the switches seem to fail fairly often, but only starting the car a dozen times per switch seems pretty ridiculous. Are the genuine Porsche switches that much better? Do you think I could have something shorting out the switch? The 914 key is the only thing on my keyring, so I know it's not an extra weight problem. When it's running, it runs great! |
Mark Henry |
Aug 12 2019, 03:25 PM
My ford solenoid mod takes the load off of the ignition switch. I don't know if it helps with the aftermarket switches.
Link in my signature below. |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:19 AM |
